Receiving BBC
10 ANTWORTEN 10
IanButcher
Nachricht 1 von 11
14.147 Aufrufe
Nachricht 1 von 11
14.147 Aufrufe
Receiving BBC
I have a Medion internet radio. I listen to the BBC (Radio 4). Regularly there are announcements that - from mid 2023 - the BBC will no longer be broadcasting on internet through the radio I have. The announcement instructs listeners to contact the manufacturer of the radio (Medion). However, I have been told (by Medion) that Medion (Germany?) has no plans to do anything about this, nor do they have any instructions to their customers. Shouldn’t Medion liaise with the BBC to evaluate what they need to do so that this important service can continue for Medion customers?
10 ANTWORTEN 10
EastClintwood
Nachricht 2 von 11
12.541 Aufrufe
Nachricht 2 von 11
12.541 Aufrufe
Hello @IanButcher, and welcome to the community.
Please let us know the MSN number of your device.
BBC will switch off support for Shoutcast if your device has the ability to listen to BBC via HLS / DASH this would be a quick solution.
Regards,
EastClintwood
IanButcher
Nachricht 3 von 11
12.530 Aufrufe
Nachricht 3 von 11
12.530 Aufrufe
Dear Clint
thanks for taking time off making movies to help……The number is 50060323
i hope that you can help.
regards
ian
EastClintwood
Nachricht 4 von 11
12.521 Aufrufe
Nachricht 4 von 11
12.521 Aufrufe
Hello @IanButcher,
Please check if the newest firmware is installed:
Check in the menu of the radio under System settings / Update software whether the menu item AUTO-UPDATE is set to YES.
You can also initiate a manual search for the firmware update under Search for software updates.
Unfortunately, there is currently no specific update planned for the BBC's shoutcast shutdown.
Regards,
EastClintwood
Buzzi
Nachricht 5 von 11
12.230 Aufrufe
Nachricht 5 von 11
12.230 Aufrufe
I have the same problem as IanButcher.
Can you please tell me how to check if the device has the ability to listen to BBC via HLS / DASH?
MSN is 5006 0292.
Thanks and regards.
IanButcher
Nachricht 6 von 11
12.222 Aufrufe
Nachricht 6 von 11
12.222 Aufrufe
Seems to be too late. As from a few days ago I can no longer get BBC Radio 4 on my internet radio. My solution is to get the channel on my iPhone then use a Bluetooth speaker to hear it better. Bit of a faff but it works. BBC seems to be shutting a lot of stuff down, especially abroad (I live in Belgium and Denmark).
Volker24
Nachricht 7 von 11
11.642 Aufrufe
Nachricht 7 von 11
11.642 Aufrufe
I have the same question. The MSN of my radio is 50060294. The radio is only 3 years old.
Mastermind
Nachricht 8 von 11
11.466 Aufrufe
Nachricht 8 von 11
11.466 Aufrufe
Hi @Volker24 ,
it seems that things behave like  IanButcher confirmed. Maybe his solution works asan alternative)
Cheers
Volker24
Nachricht 9 von 11
11.454 Aufrufe
Nachricht 9 von 11
11.454 Aufrufe
@Major_ToM Thanks, for the hint, but @IanButcher's method does not make my Medion Internet radio work. As a matter of fact, I am currently using a HomePod Mini to listen to BBC now.Thanks again.
Mastermind
Nachricht 10 von 11
11.443 Aufrufe
Nachricht 10 von 11
11.443 Aufrufe
Hi @Volker24 ,
@Volker24  schrieb:
...does not make my Medion Internet radio work.
You mean your radio is completely out of order?
Cheers
10 ANTWORTEN 10
