Medion Erazer Control Center
8 REPLIES 8
Seagrey
Message 1 of 9
Message 1 of 9
Hello,
I own a MEDION ERAZER X7853 (MD 60540) UK  MSN: 30022549 and I am unable to find on the support portal an updated version of the Control Center software.
Recentnly I have formatted my laptop and reintalled Windows 10 and I need to reinstall the Control Center.
I wrote to the support some time ago but they have not provided me with an answer regarding this matter yet.
Please, can you help?
Thanks in advance!
No downloads!No downloads!
8 REPLIES 8
Fox10
Message 2 of 9
Message 2 of 9
Hi @Seagrey
please check the recovery partition. Maybe under the Folder "Drivers" you will finde Erazer Control Center.
best regards Fox10
#Medion #Erazer #läuftbeimir
Seagrey
Message 3 of 9
Message 3 of 9
@Fox10wrote:
Hi @Seagrey
best regards Fox10
Hello @Fox10,
I have formatted my laptop thus I don't have recovery partition.
So, where can I download the Control Center software??
Message 4 of 9
Message 4 of 9
@Seagrey
Quite stupid to delete those folders without a backup of the folder Drivers, Tools and Recover.
The Software, you normally don't get from Medion, and the Drivers are usually to be downloaded on the Medion service-page.
But you could ask a Moderator, maybe @Luke or @Rex, if they could send you a copy; possibly you will have to pay for it.
regards, daddle
ertinio
Message 5 of 9
Message 5 of 9
Mate you will not be able to install the control center as you have to update bios. i have the same exact laptop x7853 and have had no luck finding the bios update
Mastermind
Message 6 of 9
Message 6 of 9
Hi @ertinio ,
can you please inform us, which BIOS version you currently installed on your MEDIOnERAZER X7853 notebook?
Cheers
ertinio
Message 7 of 9
Message 7 of 9
HI , when I installed the fresh windows pro it downgradeD the bios to 1.05.03RGME1_0006 04/02/17 AND THEREFORE UNABLE TO INSTALL the control center saying erazer does not support this platform everytime i start it. The weird part is that I can' find the update anywhere not even on the medion website mate. Could you please help with a link as i cant turn on the discreet option therefore can't play serious games.
ice-JAck
Message 8 of 9
Message 8 of 9
Wich one do i need te reinstall ?
Gehringer
Retired
Message 9 of 9
Message 9 of 9
Hi @ice-JAck ,
go to the Medion service website and check if there is a BIOS update listed at the downloads area.
Regards,
Felipe
8 REPLIES 8
