Medion Erazer Control Center
8 ANTWORTEN 8
Seagrey
Nachricht 1 von 9
29.508 Aufrufe
Nachricht 1 von 9
29.508 Aufrufe
Hello,
I own a MEDION ERAZER X7853 (MD 60540) UK  MSN: 30022549 and I am unable to find on the support portal an updated version of the Control Center software.
Recentnly I have formatted my laptop and reintalled Windows 10 and I need to reinstall the Control Center.
I wrote to the support some time ago but they have not provided me with an answer regarding this matter yet.
Please, can you help?
Thanks in advance!
No downloads!No downloads!
8 ANTWORTEN 8
Fox10
Nachricht 2 von 9
29.497 Aufrufe
Nachricht 2 von 9
29.497 Aufrufe
Hi @Seagrey
please check the recovery partition. Maybe under the Folder "Drivers" you will finde Erazer Control Center.
best regards Fox10
#Medion #Erazer #läuftbeimir
Seagrey
Nachricht 3 von 9
29.494 Aufrufe
Nachricht 3 von 9
29.494 Aufrufe
@Fox10wrote:
Hi @Seagrey
best regards Fox10
Hello @Fox10,
I have formatted my laptop thus I don't have recovery partition.
So, where can I download the Control Center software??
Nachricht 4 von 9
29.482 Aufrufe
Nachricht 4 von 9
29.482 Aufrufe
@Seagrey
Quite stupid to delete those folders without a backup of the folder Drivers, Tools and Recover.
The Software, you normally don't get from Medion, and the Drivers are usually to be downloaded on the Medion service-page.
But you could ask a Moderator, maybe @Luke or @Rex, if they could send you a copy; possibly you will have to pay for it.
regards, daddle
ertinio
Nachricht 5 von 9
27.414 Aufrufe
Nachricht 5 von 9
27.414 Aufrufe
Mate you will not be able to install the control center as you have to update bios. i have the same exact laptop x7853 and have had no luck finding the bios update
Mastermind
Nachricht 6 von 9
27.399 Aufrufe
Nachricht 6 von 9
27.399 Aufrufe
Hi @ertinio ,
can you please inform us, which BIOS version you currently installed on your MEDIOnERAZER X7853 notebook?
Cheers
ertinio
Nachricht 7 von 9
27.387 Aufrufe
Nachricht 7 von 9
27.387 Aufrufe
HI , when I installed the fresh windows pro it downgradeD the bios to 1.05.03RGME1_0006 04/02/17 AND THEREFORE UNABLE TO INSTALL the control center saying erazer does not support this platform everytime i start it. The weird part is that I can' find the update anywhere not even on the medion website mate. Could you please help with a link as i cant turn on the discreet option therefore can't play serious games.
ice-JAck
Nachricht 8 von 9
25.616 Aufrufe
Nachricht 8 von 9
25.616 Aufrufe
Wich one do i need te reinstall ?
Gehringer
Retired
Nachricht 9 von 9
25.586 Aufrufe
Nachricht 9 von 9
25.586 Aufrufe
Hi @ice-JAck ,
go to the Medion service website and check if there is a BIOS update listed at the downloads area.
Regards,
Felipe
8 ANTWORTEN 8
