Medion Control Centre
25 ANTWORTEN 25
Ikari_00
Nachricht 1 von 26
39.444 Aufrufe
Nachricht 1 von 26
39.444 Aufrufe
Hello, I recently purchased a refurbished Medion Erazer X7853 which has had its hard drives reformatted. As a result, I do not have the Medion Control Center installed onto my laptop which means that I cannot access the RGB keyboard. I have looked for a download link online but have not had any results. Would anyone be able to provide a download link to it? Thanks.
2 AKZEPTIERTE LÖSUNGEN
TPFLegionaire
Retired
Nachricht 11 von 26
34.632 Aufrufe
Nachricht 11 von 26
34.632 Aufrufe
hi @Ikari_00
Realy pleased to hear it has worked for you. this is great! Let us know if there is anything else we can do to help.
@Fishtown access is one thing, finding what you are lookingfor , now that is the challenge! Teamwork, community that is the key ,for if I fail, someone else will help and in this instance it was you @Fishtown ! Many thx.
Cheers!
TPFLegionaire
MEDION AG - A Lenovo Company • • Community: community.medion.com
Please reward helpful posts with Kudos and mark solutions with Accept as solution.
Nachricht 12 von 26
34.971 Aufrufe
Nachricht 12 von 26
34.971 Aufrufe
Moin @Ikari_00 ,
if the contribution is solved for you, mark it as such, thank you.
here again the direct link to the controll center: http://cdn.medion.com/downloads/treiber/ctrx785x_w10.exe
Teamworker@TPFLegionaire , thanks for the enlightening answer
Tschüss Teamplayer Fishtown
if you are looking for something let me know.Smiley (zwinkernd)Lachender Smiley
25 ANTWORTEN 25
TPFLegionaire
Retired
Nachricht 2 von 26
21.078 Aufrufe
Nachricht 2 von 26
21.078 Aufrufe
Hi @Ikari_00
Welcome to the forum,
I will do my best to find a way to get you that software, just bear with me whilst I make some inquiries.
Iis it just the RGB software ? or is there anything else?
Cheers!
TPFLegionaire
TPFLegionaire
Retired
Nachricht 3 von 26
21.073 Aufrufe
Nachricht 3 von 26
21.073 Aufrufe
Hi @Ikari_00
Could you give the following link a try. Admitedely it is for a 7859 series so not sure if it will work , I don't have a 7853 handy to try.
If this does not work, could you tell me wich version of the BIOS you have installed on your machine and also the MSN number that you should be able to find at the back of the machine , it is eight numbers long.
Thank you for your patience and cooperation.
Cheers!
TPFLegionaire
Ikari_00
Nachricht 4 von 26
21.069 Aufrufe
Nachricht 4 von 26
21.069 Aufrufe
Thanks for the reply Legionaire and your help. I've managed to install the program but when I go to launch the program it loads for a couple seconds and then completely closes and I've tried running as an anbassador too.Perhaps this is related so I'll include this but I've tried running HotKeyTrey I get a Microsoft.NET Framework error so I'm not sure if those are somehow connected? I've also tried repairing the install but that hasn't fixed anything. The MSN code is 30022580 and the BIOS is American Megatrends INC 1.05.03RGME1_00007, 23/02/17.
TPFLegionaire
Retired
Nachricht 5 von 26
21.049 Aufrufe
Nachricht 5 von 26
21.049 Aufrufe
Hi @Ikari_00
Thank you for the additional info ,I would sugest you update your NET framework to the latest version if you haven't done so.
I am hoping that this would work, however I am still unable to find the software specificaly shipped for this model so will escalate and get back to you with an answer.
Thank you for your patience and keep me posted.
Cheers!
TPFLegionaire
Ikari_00
Nachricht 6 von 26
21.041 Aufrufe
Nachricht 6 von 26
21.041 Aufrufe
Unfortunately it hasn't worked but I appreciate your efforts so far and thank you for keeping me up to date 🙂
Nachricht 7 von 26
20.995 Aufrufe
Nachricht 7 von 26
20.995 Aufrufe
Moin @TPFLegionaire
I have this contribution found
: https://community.medion.com/t5/ERAZER-Gaming/Erazer-Kontrollzentrum-x7853-MD60708/m-p/73541#M3446
see Post 2 from burki48(Mod.) there is a link for one controll center x7853. is that the right one?
TPFLegionaire
Retired
Nachricht 8 von 26
20.991 Aufrufe
Nachricht 8 von 26
20.991 Aufrufe
@Fishtown
Good find, it's several time the size of the one I had found so maybe contain all the required librairies/files to ron on @Ikari_00 's machine.
@Ikari_00 , would you mind giving it a go?
Cheers!
TPFLegionaire
Ikari_00
Nachricht 9 von 26
20.988 Aufrufe
Nachricht 9 von 26
20.988 Aufrufe
Thank you guys that new download link has worked and solved the issues. Appreciate the support!
Nachricht 10 von 26
20.982 Aufrufe
Nachricht 10 von 26
20.982 Aufrufe
Moin @Ikari_00 ,nice that it works.
@TPFLegionaire,  a question: Do not all moderators access the same database?
25 ANTWORTEN 25
