45382members
1210online
156395posts
MSN 20064668
The following Intel processors can be installed on socket 1151 up to max. 95 W TDP:
There are 2 memory slots on the mainboard, each of which can hold 16 GB of RAM. The maximum capacity is therefore 32 GB.
| Module: | 288-Pin DIMM |
| Type: | SDRAM-DDR4 |
| Tact: | 2666 MHz |
| Voltage: | 1,2 V |
| Special feature: | No ECC support |
⚠️Note⚠️ Please note that in the 32-bit editions of Windows operating systems, a maximum of approx. 3.2 GB of memory is recognised. You can find more information on this on the Microsoft website.
| Slot | Connection | Dimensions | Key(s) | Comment |
| 1 | SATA | 2260, 2280 | B Key | |
| 2 | PCIe | 2260, 2280 | M Key | Optane Ready |
| 3 | 2230 | E Key | only WLAN |
⚠️Note⚠️ You will need a screw with a metric M2 thread and a length of between 2.5 mm and 3.0 mm for fastening. The head should have a diameter of 4 mm to a maximum of 5 mm. If the screws are not available from your local specialist retailer, you can find them online.
The front PIN assignment can be seen in the illustration.
Article in other languages:
Review Date: 2025-05-14
