45245members
1575online
156067posts
MSN 20062962
There are 2 memory slots on the mainboard, each of which can hold 16 GB of RAM. The maximum capacity is therefore 32 GB.
| Module: | 288-Pin DIMM |
| Type: | SDRAM DDR4 |
| Clock: | 2666 MHz |
| Voltage: | 1,2 V |
| Special feature: | no ECC-support |
⚠️Note⚠️ In the 32-bit editions of Windows operating systems, a maximum of approx. 3.2 GB of memory is recognised. You can find more information on this on the Microsoft website.
| Slot | Connection | Dimensions | Key(s) | Note |
| 1 | PCIe NVMe, SATA | 2260, 2280 | B & M key | |
| 2 | 2230 | E key | only WLAN |
The front PIN assignment can be taken from the illustration.
