How do I update the firmware for the MEDION P85731 (MD 90731) / MEDION P85770 (MD 90770) / MEDION P85774 (MD 90774) alarm system?
Proceed as follows:
Enter (bottom right).star key [CLR] (bottom left).1 button to start it.1 button on the alarm control panel again to start.The app then switches to update mode and after a few seconds the display of the alarm centre shows the download in percent (%). The duration of the update is at least 3 to 4 minutes, depending on the Internet connection. After successful download of the firmware, the system restarts automatically. You can then check the new firmware version in the device manager of the app.
Depending on the number of sensors present, it can take up to an hour until all the corresponding information has been exchanged and synchronised with the cloud. During this phase, the WLAN-LED flashes to indicate that data exchange is taking place. In this situation, the flashing should not be confused with a missing WLAN connection. As soon as the process is complete, the WLAN-LED lights up permanently again.
⚠️Note⚠️:
From time to time, the app seems to be inoperable for a short time. During this phase, however, all sensor events are still reported to the app. It automatically switches back to operating mode after a short time. With a restart of the app, it is immediately back in operating mode.
Article in other languages:
Review Date: 2024-05-09
