45522members
1786online
156783posts
How can I turn off the standby LED on my MEDION TV?
Since it is not a basic function, it is not possible on all TVs.
You can check whether your device offers this feature in the settings. Open the Settings menu with the menu button on the remote control and select More settings.
The standby LED can be deactivated here. If the menu item is not available, the LED can only be deactivated by completely disconnecting the device from the power supply with the power switch.
