45557members
1382online
156908posts
The CPUs are soldered (BGA socket) and can therefore not be exchanged.
There are 2 memory slots on the mainboard each with max. 32 GB RAM. The maximum capacity is therefore 64 GB.
| Module: | 260-Pin SO-DIMM |
| Type: | SDRAM DDR4 |
| Speed: | 3200 MHz |
| Voltage: | 1.2 V |
| Feature: | no ECC Support |
Please note that in the 32-bit editions of Windows operating systems a maximum of about 3.2 GB memory is detected.You can find more information about this on the Microsoft website.
| Slot | Interface | Dimensions | Key(s) | Hints |
| 1 | PCIe 3.0 | 2280 | M-key | max. size 2 TB |
| 2 | PCIe 3.0 | 2280 | M-key | max. size 2 TB |
Note: M.2 ports have only one key, although M.2 combination cards with B-key and M-key can be installed.
No, the graphics card is onboard (soldered).
No, it is not possible to install an HDD.
Article in other languages:
Review Date: 2022-10-19
