How to open the case of my notebook?
Question
How can I open the case of my laptop?
Answer
To open the case, you need to loosen the screws on the bottom part first.
The case halves are connected by plastic clips. These clips can be loosened with a tool, e. g. a check card, guitar pick or other soft an narrow objects. To do this, carefully push the tool between the two halves of the case and go around the entire case. Afterwards the two halves of the case can be separated.
Important: If a product is intended for proper upgrading or retrofitting, there are appropriate options to open the housing. It is important to note, that we only guarantee the flawless function of the product when it is delivered. Subsequently installed third-party hardware or software, as well as problems or damage caused in this context, are excluded from the warranty and from our guarantee.
Version history
Last update:
‎04.11.2024 13:34
Updated by:
Labels (2)
