no signal in my monitor
3 REPLIES 3
TINA72
Message 1 of 4
Message 1 of 4
Hello everyone anybody can help me my monitor displays no signal when i turn on my pc
Tags (1)
3 REPLIES 3
SlamRam
Retired
Message 2 of 4
Message 2 of 4
Hello @TINA72, welcome to the community!
To help you with this case we would require some further information. Could you please provide us with the MSN or MD number of the monitor you are using and what type of cable you are using when attempting to connect your PC to the monitor?
Cheers!
SlamRam
MEDION AG - A Lenovo Company • • Community: community.medion.com
Please reward helpful posts with Kudos and mark solutions with Accept as solution.
TINA72
Message 3 of 4
Message 3 of 4
Hello thanks to your SlamRam but when I attempt to plug in it blast away and it burns the power supply of my pc I don’t know now what to do
SlamRam
Retired
Message 4 of 4
Message 4 of 4
Hello @TINA72, thanks for getting back to us.
Firstly, please could you provide us with the MSN or MD number of the monitor you are using? This can be found either on the back of your monitor or on the box.
Can you please elaborate on what you are plugging in to your PC to cause an issue with the power supply? What connection cables are you using to connect your monitor to your PC?
Cheers!
SlamRam
3 REPLIES 3
