Medion TV Wireless display
11 RÉPONSES 11
Fvogels
Message 1 sur 12
53 103 Visites
Message 1 sur 12
53 103 Visites
Hi everybody,
I recently bought a Medion TV. The TV should have the so called "wireless display" function. However I walked into the following problem:
I do find the Wireless Display option in my input list, but as soon as I select it, the TV loses the internet connection. As a result my phone can't find the TV to cast to.
To be sure of my conclusion I even used the Medion Wireless remote app with which I selected the Wireless Display input. As soon as I did that, I couldn't use the Wireless remote app anymore (which indicates that the internet connection of the TV is lost, as the Wireless remote app is based on an internet connection). So it definitely is the internet connection of the TV that is the issue.
I do have to mention that I have never had difficulties with the internet connection of the TV when using Netflix or YouTube, the problem only pops up when I want to use the Wireless Display function.
Is there anybody that knows the problem and/or knows a solution to the problem??
Thanks in advance!!!
Vogels
Balises (5)
11 RÉPONSES 11
Gehringer
Retired
Message 2 sur 12
46 860 Visites
Message 2 sur 12
46 860 Visites
Hi @Fvogels and welcome to the FORUM!
Can you please provide the MSN number of your TV?
It is an eight-digits number printed in the label behind your TV.
It should probably start by 300 or 500
In the meanwhile, because your wireless connection works fine with other apps, I think it may be a matter of configuration.
Have you already tried to restore your TV to its factory settings (aka first time configuration)?
Regards,
Gehringer
Fvogels
Message 3 sur 12
46 852 Visites
Message 3 sur 12
46 852 Visites
Hi @Gehringer, thanks for your reaction.
No, I have not tried to reset the TV to its factory settings, I could try that.
However I would prefer to wait  for your possible solution because I will lose all my settings :).
Because I mounted my TV to the wall, and a metal component of that mount is in front of the 8 digit code I can't give you my MSN code. I do however have the type code for you: MEDION LIFE P13284/MD31384.
I hope you know what the problem could be! Thanks in advance.
Vogels
Message 4 sur 12
46 848 Visites
Message 4 sur 12
46 848 Visites
@Fvogels
The MSN number you also can find on the box, in which the TV was packed. You should keep the box if possible anyway for later transport  by moving, or sending it to a repair place, eg Medion Service.
Gehringer
Retired
Message 5 sur 12
46 618 Visites
Message 5 sur 12
46 618 Visites
Hi @Fvogels ,
well, unfortunately in your case, the first option would be to perform a reset to the factory settings.
Regards,
Gehringer
PieterPAM
Message 6 sur 12
45 378 Visites
Message 6 sur 12
45 378 Visites
Hi,
I have the same problem with my MD32060 (50” tv screen).
I already have rest the tv to factory settings after updating the tv to the latest firmware.
hope that this will be solved soon...
GreetZ,
Pieter
PieterPAM
Message 7 sur 12
45 377 Visites
Message 7 sur 12
45 377 Visites
Hi all,
I found that I also have the problem that the information sticker of the TV is located right under the location where the wall mound base must be attached to the TV.
Suggestion to Medion:
Place the information sticker not on the location where the wall mount should be placed...
BeardGuy
Message 8 sur 12
44 451 Visites
Message 8 sur 12
44 451 Visites
I have the same problem, but with a brand new, just released Medion Life x16595 (MD 32195).
It’s really really irritating, it seems like it’s for no reason at all, I’ve looked through all the settings and can’t find anything!
Please Medion, please fix this!
PieterPAM
Message 9 sur 12
44 392 Visites
Message 9 sur 12
44 392 Visites
Hi BeardGuy,
I found the answer in the manual that it only works for Android devices and not for Apple devices....
so it seems there is not much we can do...
GreetZ,
Pieter
gescat
Message 10 sur 12
38 398 Visites
Message 10 sur 12
38 398 Visites
Which was the solution to make this work?
11 RÉPONSES 11
