MD31439 dark image
3 REPLIES 3
Gorf
Message 1 of 4
Message 1 of 4
MD31439 dark image
My TV has a dark region regardless of the source.
Is this likely to be repairable?
3 REPLIES 3
Message 2 of 4
Message 2 of 4
Hello @Gorf  and welcome
this does not look good.
you should contact medion support immediately to claim your guarantee.
before that you can try a residual current discharge but that looks more like a technical defect.
bye Fishtown
https://community.medion.com/t5/kb/en/ta-p/92923
Gorf
Message 3 of 4
Message 3 of 4
Thank you @Fishtown - I'm not entirely sure if the RCD fixed it, but it's fixed now!
I planned to contact support, but first I tried the RCD that you suggested. I left the TV off at the socket for 15min. When I turned it back on the problem was still there.
I contacted support and got an email back really quickly, maybe 90mins after sending them the issue. They recommended a factory reset before starting the returns process, but when I turned the TV on to do the reset, the screen was back to normal. I did the factory reset anyway. I don't think that they could have sent any sort of fix remotely once they had the serial number, so I think it must be the RCD that did it.
Thanks for your help 🙂
Tags (1)
Gorf
Message 4 of 4
Message 4 of 4
I spoke too soon 🙁
3 REPLIES 3
