Re: Wiederherstellungspaket für P10356
21 ANTWORTEN 21
Eck001
Nachricht 1 von 22
9.058 Aufrufe
Nachricht 1 von 22
9.058 Aufrufe
ich hab mir das Wiederherstellungspaket gezogen und versucht einzuspielen.
Leider bekomme ich nun auf meinem Tablet nurnoch das LIFETAB Logo angezeigt und er bootet nicht mehr weiter.
Beim flashen kommen auch ein paar Fehler, hauptsächlich was die oem commands betrifft.
Hier mal die Log vom Flashvorgang:
*** Intel flash process stage 1 ***
1) Power off the device.
2) Press and hold [Power]+[VolUp]+[VolDn] for 5 seconds.
3) Connect device to PC via USB.
< waiting for any device >
Sending 'osloader' (279 KB)                        OKAY [  0.016s]
Writing 'osloader'                                 OKAY [  0.003s]
Finished. Total time: 0.034s
Sending 'boot.img' (13394 KB)                      OKAY [  0.531s]
Booting                                            OKAY [  0.000s]
Finished. Total time: 0.550s
Gewartet wird  7 Sekunden. Weiter mit beliebiger Taste...
*** Intel flash process stage 2 ***
                                                   FAILED (remote: 'unknown OEM command')
fastboot: error: Command failed
                                                   (bootloader) CMD 'wipe /ESP'...
(bootloader) erasing volume "/ESP", size=67108864...
(bootloader) wrote ret 3108864, count 17,  "/dev/block/by-name/ESP"
(bootloader) read back ret 3108864, count 17 "/dev/block/by-name/ESP"
OKAY [  1.553s]
Finished. Total time: 1.561s
                                                   (bootloader) CMD 'wipe /reserved'...
(bootloader) erasing volume "/reserved", size=67108864...
(bootloader) wrote ret 3108864, count 17,  "/dev/block/by-name/reserved"
(bootloader) read back ret 3108864, count 17 "/dev/block/by-name/reserved
OKAY [  1.571s]
Finished. Total time: 1.577s
                                                   (bootloader) Start partitioning
OKAY [  0.109s]
Finished. Total time: 0.114s
Sending 'gpt' (1 KB)                               OKAY [  0.066s]
Writing 'gpt'                                      FAILED (remote: 'flash_cmds error!
******** Did you mean to fastboot format this ext4 partition?
Erasing 'factory'                                  OKAY [  0.109s]
Finished. Total time: 0.216s
Erasing 'system'                                   OKAY [  0.425s]
Finished. Total time: 0.522s
mke2fs 1.44.4 (18-Aug-2018)
Creating filesystem with 262144 4k blocks and 65536 inodes
Filesystem UUID: 2423ec38-f652-11e9-b453-5374ca118c1e
Superblock backups stored on blocks:
        32768, 98304, 163840, 229376
Allocating group tables: done
Writing inode tables: done
Creating journal (8192 blocks): done
Writing superblocks and filesystem accounting information: done
Sending 'cache' (340 KB)                           OKAY [  0.077s]
Writing 'cache'                                    OKAY [  0.103s]
Finished. Total time: 0.497s
Creating filesystem with 4096 4k blocks and 4096 inodes
Creating journal (1024 blocks): done
Sending 'config' (48 KB)                           OKAY [  0.068s]
Writing 'config'                                   OKAY [  0.096s]
Finished. Total time: 0.459s
Creating filesystem with 8192 4k blocks and 8192 inodes
Sending 'logs' (52 KB)                             OKAY [  0.070s]
Writing 'logs'                                     OKAY [  0.096s]
Finished. Total time: 0.465s
                                                   (bootloader) Stop partitioning
OKAY [  0.090s]
Finished. Total time: 0.096s
Sending 'ESP' (65536 KB)                           OKAY [  1.626s]
Writing 'ESP'                                      OKAY [  1.401s]
Finished. Total time: 3.219s
Sending 'fastboot' (13394 KB)                      OKAY [  0.387s]
Writing 'fastboot'                                 OKAY [  0.376s]
Finished. Total time: 0.945s
Erasing 'keystore'                                 FAILED (remote: 'unable to format')
Sending 'factory' (48 KB)                          OKAY [  0.067s]
Writing 'factory'                                  OKAY [  0.120s]
Finished. Total time: 0.493s
Creating filesystem with 524288 4k blocks and 131072 inodes
Filesystem UUID: 28077f4a-f652-11e9-a9de-dfa97c91c119
        32768, 98304, 163840, 229376, 294912
Creating journal (16384 blocks): done
Sending 'system' (604 KB)                          OKAY [  0.083s]
Writing 'system'                                   OKAY [  0.108s]
Finished. Total time: 0.510s
Creating filesystem with 6751227 4k blocks and 1689120 inodes
Filesystem UUID: 286370d4-f652-11e9-8f7e-7fcf03f7d078
        32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632, 2654208,
        4096000
Creating journal (32768 blocks): done
Sending 'data' (4272 KB)                           OKAY [  0.169s]
Writing 'data'                                     OKAY [  0.185s]
Finished. Total time: 0.726s
Filesystem UUID: 28de0bdc-f652-11e9-99dd-dd198a74726a
Writing 'cache'                                    OKAY [  0.106s]
fastboot: error: cannot load 'esp.zip': No such file or directory
Sending 'fastboot' (13394 KB)                      OKAY [  0.376s]
Writing 'fastboot'                                 OKAY [  0.390s]
Finished. Total time: 0.921s
Sending 'boot' (10226 KB)                          OKAY [  0.308s]
Writing 'boot'                                     OKAY [  0.325s]
Finished. Total time: 0.784s
Sending 'recovery' (10892 KB)                      OKAY [  0.315s]
Writing 'recovery'                                 OKAY [  0.325s]
Finished. Total time: 0.795s
Sending sparse 'system' 1/9 (194848 KB)            OKAY [  4.894s]
Writing 'system'                                   OKAY [  4.063s]
Sending sparse 'system' 2/9 (202286 KB)            OKAY [  5.067s]
Writing 'system'                                   OKAY [  4.299s]
Sending sparse 'system' 3/9 (204775 KB)            OKAY [  5.320s]
Writing 'system'                                   OKAY [  4.439s]
Sending sparse 'system' 4/9 (204746 KB)            OKAY [  5.210s]
Writing 'system'                                   OKAY [  4.591s]
Sending sparse 'system' 5/9 (200541 KB)            OKAY [  5.045s]
Writing 'system'                                   OKAY [  4.105s]
Sending sparse 'system' 6/9 (195662 KB)            OKAY [  5.192s]
Writing 'system'                                   OKAY [  4.065s]
Sending sparse 'system' 7/9 (199541 KB)            OKAY [  5.014s]
Writing 'system'                                   OKAY [  4.244s]
Sending sparse 'system' 8/9 (183646 KB)            OKAY [  4.572s]
Writing 'system'                                   OKAY [  3.962s]
Sending sparse 'system' 9/9 (82060 KB)             OKAY [  2.133s]
Writing 'system'                                   OKAY [  1.756s]
Finished. Total time: 81.260s
Sending 'capsule' (5624 KB)                        OKAY [  0.215s]
Writing 'capsule'                                  OKAY [  0.295s]
Finished. Total time: 0.665s
Resuming boot                                      OKAY [  0.048s]
Finished. Total time: 0.055s
*** Finished.                   ***
Wäre super wenn mir jemmand helfen könnte.
21 ANTWORTEN 21
Eck001
Nachricht 2 von 22
6.796 Aufrufe
Nachricht 2 von 22
6.796 Aufrufe
ich habe gerade festgestellt das das Tablet nun doch bootet, aber immer nur in den abgesicherten modus.
Dann hab ich zusätzlich noch herausgefunden das meine leiser-Taste wohl klemmt und es wohl deswegen in den abgesichtern Modus geht.
Ich denke fast das da nichtsmehr zu machen ist oder hat einer von euch eine Idee?
Nachricht 3 von 22
6.815 Aufrufe
Nachricht 3 von 22
6.815 Aufrufe
Hallo @Eck001 und herzlich willkommen in der Community.
Wenn ein hardwaremäßiger Defekt bezüglich der Taste vorliegt und es nicht auszuschließen ist, dass das der Grund für Flash- oder Bootprobleme ist, haber ich auch keine Idee mehr. Das Gerät müsste dann repariert werden.
Nachricht 4 von 22
6.812 Aufrufe
Nachricht 4 von 22
6.812 Aufrufe
@Manuel30
Versuche Mal ob du mit einer kräftigen Nadelspitze die klemmende Taste lösen kannst. Oder du clipst den hinteren Deckel ab, dann kommst du besser dran
Was meintest du mit abgesicherten Modus? Den Droidbootmodus, in dem du im kleinen Fenster auswählen kannst Recovery, System, Power Off?
Dann versuche doch mal im Recovery einen factory reset, wenn das sich überhaupt starten lässt Oder zuerst einen 'wipe cache', dann neuen Installationsversuch.
Eine Reparatur würde sich nicht lohnen, da dafür das Mainboard getauscht werden müsste.
Oder du suchst in der Bucht nach einem preiswertem Bastlergerät, daß "nur" einen Displayschaden hat, dann kann man dessen Mainboard in dein Tablet einbauen.
Manuel30
Explorer
Nachricht 5 von 22
6.761 Aufrufe
Nachricht 5 von 22
6.761 Aufrufe
Eck001
Da das Wiederherstellungspaket für P10356 bei dir doch funktioniert, du aber irgendwie, wieso auch immer in den abgesicherten Modus kommst.
Bitte ich darum in einem eigenen Thread zu lösen.
Hier geht es ausschließlich nur um das Wiederherstellungspaket für P10356.
Daddle:
Du hast im übrigens den falschen angesprochen, du meinst wohl eher Eck001.
Und ich bitte darum, um weiteren Off-Topic zu vermeiden, das Thema hier zu schließen.
Das Wiederherstellungspaket für P10356 funktioniert einwandfrei, sonst hätte ich dies, bevor mein Tablet total kaputt ging. Noch weiter bemängelt..
Hier zu mache ich im übrigerns aufmerksam auf meine Authorenrechte
Außer dass die 3 Dateien eventuell? noch weiterhin fehlen.
Rex
Community Manager
Community Manager
Nachricht 6 von 22
6.746 Aufrufe
Nachricht 6 von 22
6.746 Aufrufe
Ursprungs-Thread geschlossen und neues Thema abgetrennt.
Rex
Nachricht 7 von 22
6.719 Aufrufe
Nachricht 7 von 22
6.719 Aufrufe
@Eck001
Versuche mal ob du mit einer kräftigen Nadelspitze oder Skalpellspitze die klemmende Taste lösen kannst. Oder du clipst zuerst den hinteren Deckel ab, dann kommst du besser an den Schalter dran.
Was meintest du mit abgesicherten Modus? Den Droidbootmodus, in dem du im kleinen Fenster auswählen kannst: Recovery, System, Power Off?
Dann versuche  im Recovery einen factory reset zu  machen, wenn das sich überhaupt starten lässt.
Oder zuerst einen 'wipe cache' starten, danach neuen Installationsversuch.
Eine Reparatur würde sich nicht lohnen, da dafür das Mainboard getauscht werden müsste, den Medion lötet nicht auf der Hauptplatine.
Das ist eine Kopie meines Posts 4, diesmal an den richtigen Adressaten.
Gruß, daddle
Nachricht 8 von 22
6.671 Aufrufe
Nachricht 8 von 22
6.671 Aufrufe
@Eck001
So wie ich das sehe hast Du unter Windows geflasht. Und vermutlich ohne Optionen wie  -update,  -force oder  -nobios. Und hattest DU das richtige  Wiederherstellungspaket für das P10356 genommen? Und nicht das  für die S1035X  Serie?
Da diese in der Software-Übersicht generell als S1035X  benannt werden, könnte man sich dabei mal leicht vertun und diese statt dem für das P10356 runtergeladen haben.
In deinem Flash-Protokoll sind  ein paar Einträge über fehlgeschlagene  fastboot.exe  Flashversuche, die da  m.E. nach nicht hingehören.
Aber in dem Wiederherstellungspaket für dein  P10356 fehlen mehrere Dateien, vor allem die fastboot exe. Es ist zwar eine "fastboot" ohne Endung im Verzeichnis dabei, aber das ist die Linux Version, die unter Windows nicht funktionieren kann. Und die fastboot.exe für Windows fehlt.  Daher konnten etlich Befehle nicht ausgeführt werden und kamen die  -->  Fastboot:  error:  command failed    Einträge.
Vielleicht sind es aber nur die Formatierbefehle, die fehlschlugen, sodass das Flashen durch überschreiben doch erfolgreich war.
Es fehlen die:
AdbWinApi.dll
AdbWinUsbApi.dll
fastboot.exe
Ich habe die passenden Dateien im Google Drive hochgeladen; du kannst sie downloaden, entpacken und in das Flashverzeichnis mit den Wiederherstellungsdaten einkopieren.
Danach nochmal die flash.bat starten, auf die Anzeige im aufpoppenden cmd-Fenster  < waiting for device> warten, dann beim ausgeschaltetem Tablet
--> Drücke  und halte  beide Lautstärketasten und die Ein-/Aus-Taste gleichzeitig,
--> bis auf dem Bildschirm des Tablets die Meldung „Entering DnX mode“ erscheint
--> Erst dann das Tablet mit dem USB-Kabel mit dem PC verbinden
--> Dann sollte der Flashvorgang erneut starten
Ich hoffe die fraglich klemmende Lautstärketaste hast Du lösen können; und sollte beim Starten des DnX-Modus
auf keinen Fall stören.
Eine Rückmeldung über dein weiteres Vorgehen und ob es nach Einfügen der Dateien geklappt hat wäre sehr schön.
Gruß, daddle
Anonymous
None
Nachricht 9 von 22
1.814 Aufrufe
Nachricht 9 von 22
1.814 Aufrufe
der thread ist reichlich alt und die kleine Mimose mit seinen "Authorenrechten" bezgl. 3 fehlender files im "recovery Paket" für das P10356
ist anscheinend auch glücklich geworden...
So, da ich mir z.Zt. das Rauchen abgewöhne, hab ich angefangen alte Hobbies zu reaktivieren... ich habe ein P10356, daß ich vor Jahren
versucht habe mit Cyanogen bzw. LineageOS "etwas besser zu machen"... das hat zwar mit installieren funktioniert, allerdings bleibt´s bei
schwarzem Bildschirm... das hat dann auch mit Android-X86 oder mit verschiedenen Linux Distros (mit minimalem Speicherbedarf) nicht
geklappt... also, jetzt wieder zurück zu dem alten Lollipop, damit wenigsten ein bisschen funktioniert...
Recovery Paket gestartet (unter Win11), Fastboot Mode am Tablet, Kabel angesteckt... bis hierhin läuft das, dann nix mehr:
batch bleibt da stehen...batch bleibt da stehen...Tablet bleibt da stehen....Tablet bleibt da stehen....
Sieht so aus also ob die eine Seite auf die andere wartet... ich habe ein, zwei Tests gemacht, d.h. ich habe die .bat verbogen, damit die Lösch-
und Formatbefehle ohne Vorbedingung aufgerufen werden, bekomme aber hauptsächlich nur Fehlermeldungen...
Also, hat vielleicht irgendjemand (ausser Manuel) eine Idee wo's hängen könnte?
Vielen Dank im Voraus!
VG, bollland
Nachricht 10 von 22
1.738 Aufrufe
Nachricht 10 von 22
1.738 Aufrufe
@Anonymous
Es  kann sein  dass durch die Experimente mit Cyanogen oder Lineage( wie kamst du darauf, es gibt von denen kein  CustomRom für dein Tablet!) der Bootloader gelöscht oder der falsche geflasht wurde.
Zum Flashen des Wiederherstellungspaketes, hast du allle Voraussetzungen erfüllt? Mit welchem Betriebssystem versucht du es? In Win 10 ist generell nicht so gut, besser ginge es mit Windows 7.
2. Hast du die digitale Speichersignierung vor Installatíon der Android ADB Treiber deaktiviert? Geht in Windows 10 in Win RE.  Bzw. hast du diese Treiber überhaupt installiert? Es steht zwar dass ein Hinweis käme, aber der bleibt  aus, auch  wenn die digitale Signierung  vorher nicht deaktiviert wurde. Dann denkt man die Treiber seien funktional installiert, de facto ist es aber nicht so.
 Schließe  das Tablet über USB an deinen Rechner an, und kontrolliere im Geräte Manager  ob ein Android Gerät angezeigt wird. Ohne dies geht nix. Dei tfeiber hab eicch nich irgendwo.
Schicke mir mal bitte die Auflistung aller Dateien aus dem Verzeichnis per PN , indem alle Flashdateien drin enthalten sind. (Geht mit Markieren im Total Commander) sehr einfach
Oder falls du es mit Linux versuchst, müssen die UDEV Regeln angepasst werden.
2. Falls Sie Ubuntu Linux verwenden, erstellen oder bearbeiten Sie die folgende Datei (benötigt root-Rechte):
/etc/udev/rules.d/51-android.rules
Fügen Sie folgende Zeile hinzu und speichern Sie die Datei:
SUBSYSTEM=="usb",ATTR{idVendor}=="8087", MODE="0666", GROUP="plugdev"
21 ANTWORTEN 21
