Medion lifetab p8314
31 ANTWOORDEN 31
fioor
Bericht 1 van 32
17.933 Weergaven
Bericht 1 van 32
17.933 Weergaven
Hello! I have a trouble with installing update 2 on this tablet! Sorry for my band english! Here's photo of error!
https://postimg.org/image/nv0yarc7r/
31 ANTWOORDEN 31
fioor
Bericht 11 van 32
7.278 Weergaven
Bericht 11 van 32
7.278 Weergaven
Hi @RS13,
Hello,thank you for fast answer, i will wait for results! I hote it will be good results)
Luke
Community Manager
Bericht 12 van 32
7.254 Weergaven
Bericht 12 van 32
7.254 Weergaven
Hi @fioor,
Our Android Team just sent us the relevant infos.
Here is the correct update sequence:
MP: 0da85c2.0724.1420
OTA Update #1: 0da85c2.1009.1359
OTA Update #2: 160307.0240.a176256
According to your screenshot, your device is on the "MP" stage, and the error-text says
that it`s demanding OTA #1 first. Therefore we assume that you are trying to update from
"MP" to OTA #2 without installing OTA #1 first. This will not work.
Our Android Team also provided a detailed PDF-Manual how to install both OTA #1 and #2
in English with Russian screenshots. I`ll send it to you via PN in some minutes.
Greetings,
Luke
fioor
Bericht 13 van 32
7.244 Weergaven
Bericht 13 van 32
7.244 Weergaven
Hi
I dont receive ota 1, i always receive ota 2! Maybe if you cant send me ota 1 and ota 2 via email, i can solve this problem! I also tried to factory reset, wipe cache partition, and also i receive ota 2,not ota 1!
Luke
Community Manager
Bericht 14 van 32
7.234 Weergaven
Bericht 14 van 32
7.234 Weergaven
Hi again @fioor,
According to the picture showing the error message , your device is still at MP stage. This does not fit together.
Our Android-Team has tested the OTA chain from MP to OTA #1 and OTA#2 successfully twice, so they cannot reproduce the issue here.
Perhaps you could also provide a screenshot of the system settings?
Please go to
“System -> Settings -> About your device”
and take a screenshot with the “Build Number” visible in it.
Next, on the same screen, please press “Status”, scroll down a little and take another screenshot that shows the serial number of your device.
Thanks for your cooperation,
Luke
fioor
Bericht 15 van 32
7.226 Weergaven
Bericht 15 van 32
7.226 Weergaven
Bericht 16 van 32
7.208 Weergaven
Bericht 16 van 32
7.208 Weergaven
@fioor
Did you make use of xposed and restored a backup? This probably could explain the difference in  release keys shown in recovery and in system settings.
On the other hand, an error in /cache/recovery/block map happened more often whilest updating this tablet, so I guess it should be sent into service to get it reflashed with the complete firmware.
Regards, daddle
fioor
Bericht 17 van 32
7.206 Weergaven
Bericht 17 van 32
7.206 Weergaven
I dont install xpossed, bought this tablet with this firmware, maybe i can install stock firmware by myself! I found stock firmware on offsite, can i install that firmware?
Bericht 18 van 32
7.199 Weergaven
Bericht 18 van 32
7.199 Weergaven
Hi @fioor, is  it a second hand tablet?
Where did you find a original firmware for this tablet? I can not say anything about it because I do not know this "special" firmware. Maybe you could send me the link for it by private notice?
fioor
Bericht 19 van 32
7.121 Weergaven
Bericht 19 van 32
7.121 Weergaven
Hi @Luke,
Do you have any solutions about my problem? Maybe your android team can send me stock firmware or update 1?
Luke
Community Manager
Bericht 20 van 32
7.076 Weergaven
Bericht 20 van 32
7.076 Weergaven
Hello @fioor,
Did you see the last answer sent by @daddle ?
31 ANTWOORDEN 31
