EFI - correct boot order
4 ANTWOORDEN 4
ZAJDAN
Bericht 1 van 5
7.343 Weergaven
Bericht 1 van 5
7.343 Weergaven
Hello,
my tablet doesn't start Android system and boot into EFI sheel. So I followed the instruction here:
https://www.medion.com/gb/service/_lightbox/software_details.php?did=15047
but after that I connect the USB is boots again into EFI shell with a bit other information and during a few second tablet reboots and does it again, again, again....DSC_0227.JPG
dmpstore: cannot open file - 'fs1:\ boot order.bin'
why fs1 when the USB is fs0 ...?
Tags (3)
4 ANTWOORDEN 4
Bodgekin
Bericht 2 van 5
7.282 Weergaven
Bericht 2 van 5
7.282 Weergaven
Hi @ZAJDAN
I'm not really into Android at this level, but are you sure that FS1 should be FS0? If so, cant you just open startup.nsh in notepad and change fs1:\bootorder.bin to fs0:\bootorder.bin? Or is that thinking to simple?
Kind regards,
Bart
ZAJDAN
Bericht 3 van 5
7.278 Weergaven
Bericht 3 van 5
7.278 Weergaven
@Bodgekin
Thank You for hint, but exactly this I have tried, but unfortunately it doesn't solve the problem. Seems, that the tablet has broken primary volume where is recorded OS(Android).
Bodgekin
Bericht 4 van 5
7.274 Weergaven
Bericht 4 van 5
7.274 Weergaven
Hi @ZAJDAN
I already thought it sounded to good (easy) to be true. As I said, I'm afraid this is beyond my level of knowledge of Android, sorry!
Kind regards,
Bart
Bericht 5 van 5
7.264 Weergaven
Bericht 5 van 5
7.264 Weergaven
@ZAJDAN wrote:
Hello,
@ZAJDAN
I guess fs0 is the eMMC-HD; and he looks for bootorder.bin on fs1 (usb-stick), which he can not find; or the stick or the file bootorder.bin. So something is wrong with your usb-stick, maybe the otg-adapter (usb host cable), or the connection with the stick.
4 ANTWOORDEN 4
