EFI Boot Fix - doesn't help
18 REPLIES 18
ZAJDAN
Message 1 of 19
Message 1 of 19
Hello,
I have the known problem where a tablet boots into efi shell. So I try to use EFI Boot Fix .
Flash drive is formated as fat32, EFI Bott Fix files are placed on the flash drive. I connect the FlashDrive via OTG to tablet and powerOn the tablet.
The result is, that tablet doesn't start Android OS and again do the same problem. I captured a screenshot from the tablet durring the fixing process.
Thanks for any hints
Tags (2)
18 REPLIES 18
Message 2 of 19
Message 2 of 19
@ZAJDAN
May be try with a smaller USB-Stick (512 MB or 1 GB), and / or try Fat 16, although Fat 32 did work with other machines.
ZAJDAN
Message 3 of 19
Message 3 of 19
ok....I destroyed partition on the USB Flash stick (6GB) and created there just one 512MB as FAT16,
placed there the boot fix files and again repeat the process...result is same as before.
Do You think, that the USB Flash stick have to be physical size max 1GB ?
thnx Regards ZAJDAN
Message 4 of 19
Message 4 of 19
@ZAJDAN
Ok, try it with a small Fat 32 - Partition also. Maybe the 6 GB-Stick-Controller isn't compatible. I have no idea.
As I said, I woud try with a smaller Stick max. 4 Gb, and test it again with Fat 32;
regards, daddle
ZAJDAN
Message 5 of 19
Message 5 of 19
@daddle
Friend borrowed me old USB Stick 512MB. I tried it with FAT16 and also with FAT32 ->result--->same problem presists 😞
Seems, that EFI is broken.
I disconnected the USB and boot into efi shell to try display internal volume
Shell>vol   vol: 'NULL' is not mapped
it doesn't looks nice
Message 6 of 19
Message 6 of 19
@ZAJDAN
You should ask a Mod, @TheDoctor or @Luke; I can not help you with your problem.
Regards, daddle
Edit: They should also read the flash-history for the recovery-package
TheDoctor
Specialist
Message 7 of 19
Message 7 of 19
daddle schrieb:
@ZAJDAN
Regards, daddle
Ich bin etwas überfragt. Welches Gerät ist es denn überhaupt? Liegen die Dateien an der richtigen Stelle?
> Entpacken Sie diese Datei auf den USB Stick, und zwar derart, dass die beiden
> enthaltenen Dateien direkt im Wurzelordner des Sticks liegen.
Stick ist halbwegs unkritisch. Sollte nur möglichst einfach partitioniert (ideal: 1 primäre Partition) und formatiert (VFAT) sein.
Grüße
Der Doktor
Message 8 of 19
Message 8 of 19
@TheDoctor
Infos und Nachtrag zur Vorgeschichte: -> http://community.medion.com/t5/Tablet/ANDROID-RECOVERY-PAKET/m-p/41977#U41977
 Dass er die Dateien bootorder.bin und startup.nsh  nach dem Entpacken in das Wurzelverzeichnis kopiert habe ich angenommen.
ZAJDAN
Message 9 of 19
Message 9 of 19
@TheDoctor
  • - MEDION LIFETAB P7332 Series
  • - the files are placed into Root of USB volume
  • - the USB volume is formates as VFAT, one partition only
@daddle
thanks for assistance
Message 10 of 19
Message 10 of 19
Hast Du den Stick mit einem USB-Host-Adapter, auch OTG-(On the Go)-Adapter genannt angeschlossen? War ein solcher bei dem Tab mitgeliefert?
18 REPLIES 18
