App schließt sich beim Start von alleine
157 RÉPONSES 157
blachra1nz
Message 1 sur 158
68 490 Visites
Message 1 sur 158
68 490 Visites
Seit Tagen schließt sich die App beim Start immer. Kann demnach auf das System nicht mehr zugreifen. Neuinstallation hat nichts gebracht . Beim Tablet das gleiche:-((
Andoid Galaxy Tab und Galaxy S10
157 RÉPONSES 157
esek
Message 41 sur 158
4 113 Visites
Message 41 sur 158
4 113 Visites
Hello all,
I have registered just to confirm that from a few last days I am experiencing exactly the same behaviour... the app is crashing just after logging process. I am getting the same result on my two android devices - Samsung S10e and LG k3 with different Android versions. Does not matter if I am connected via wifi or LTE, tried to uninstall the app , clear the cache etc - it doesn't help at all.
Medion this is a joke, really! You are well aware of the issue experienced by so many people and still after few days you are unable to provide a fix.
I am assuming you are not manufacturer of the devices but buying just an importer buying everything from China and you have just created your own app using the API interface enabled by the Chinese company which has developed the product. I am guessing now the issue is somewhere on the backend end and you have simply nothing to say because you do not control anything.... and maybe this Chinese company does not really care you and your customers!
I have made a big mistake and invested my money in a cheap Chinese solution 😞 Was really hoping I am buying products with a good support from German company.
Disappointed!
blachra1nz
Message 42 sur 158
4 105 Visites
Message 42 sur 158
4 105 Visites
Muss mich verbessern.  Ging genau 2x ... jetzt der gleiche Fehler wieder. Ohje
BW
Explorer
Message 43 sur 158
4 059 Visites
Message 43 sur 158
4 059 Visites
Hilfe, weiß denn keiner einen Rat?
Message 44 sur 158
4 037 Visites
Message 44 sur 158
4 037 Visites
Moin @Bodo_Olschewski
um deine Frage zu beantworten, habe ich es ausprobiert.
1.)Tablet an / Wlan eingeschaltet / App automatisch angemeldet / läuft.
    Nutzer abgemeldet / App geschlossen / Wlan aus.
    Wlan an / App aktiviert / anmelden mit Passwort / läuft.
2.)App - Nutzer abgemeldet / Wlan aus.
    App an /anmelden mit passwort (Hinweis keine Netzwerkverbindung) zurück zur Passworteingabe
    Wlan an / Passwort / läuft.
ausprobiert mit:
Lifetab E10414 mit Android 9.0
Samsung Galaxy S8, Android 9.0(zur Zeit nicht verfügbar, hat die Frau mit)
Samsung Galaxy Tab A(2016), Android 8.1.0
blachra1nz
Message 45 sur 158
4 013 Visites
Message 45 sur 158
4 013 Visites
Kann ja aber so ein Spektakel nicht jedes mal machen. Das nervt. Medion muss nachbessern....bloss das dauert immer ewig. Auf IOS keine Probleme.. .
onefinger
Explorer
Message 46 sur 158
4 011 Visites
Message 46 sur 158
4 011 Visites
@Fishtown: Du hast die 90774, ich die ältere 90770. Da wird wohl der Unterschied sein. Alles mit Androide geht bei mir nicht. iPad läuft...
LG
Peter
Quick67
Message 47 sur 158
4 005 Visites
Message 47 sur 158
4 005 Visites
Eben konnte ich mich mit meinem S9+ wieder anmelden. Die APP startete normal,
die Verbindung zur Alarmanlage war da.
Ich habe dann das A5 2017 genommen und wollte mich damit auch anmelden. Hier funktionierte die App nicht und stürzte direkt ab.
Wieder mit dem S9+ getestet und nun ging das auch nicht mehr.
Alles sehr merkwürdig.
WLAN an und aus bringt bei mir auch nichts. Fritzbox neu gestartet, auch nicht besser.
BW
Explorer
Message 48 sur 158
3 993 Visites
Message 48 sur 158
3 993 Visites
Mir kam heute Idee mit dem Apple Handy meiner Tochter die App runterzuladen und mich anzumelden und siehe da es läuft einwandfrei. Es scheint also so dass das wirklich ein reines Android Problem ist denn bei mir läuft es auf drei Android-Handys und auf dem Android Tablet gar nicht seid der Winterzeit meiner Meinung nach
BW
Explorer
Message 49 sur 158
3 912 Visites
Message 49 sur 158
3 912 Visites
Alle Möglichkeiten X mal ausprobiert. Es funktioniert weiterhin auf drei verschiedenen Handys und auf dem Tablet nicht.!!!
BW
Explorer
Message 50 sur 158
3 901 Visites
Message 50 sur 158
3 901 Visites
Du sprichst mir aus der Seele. Ich höre überall auch die gleichen Kommentare sogar von Medion Mitarbeitern. Und es ist offensichtlich dass es da ein großes Problem gerade gibt.
157 RÉPONSES 157
