reinstall windows
2 REPLIES 2
fuzzy1973
Message 1 of 3
Message 1 of 3
reinstall windows
I have a desktop pc and the hard drive failed and I have installed new hard drive but can not find serial number to put windows back on
1 ACCEPTED SOLUTION
Datwozza
Message 2 of 3
Message 2 of 3
Hi,
Do you mean the Windows activation code?
If you have re-installed Windows it should already be activated as your motherboard should have a key assigned to it.
2 REPLIES 2
Datwozza
Message 2 of 3
Message 2 of 3
Hi,
fuzzy1973
Message 3 of 3
Message 3 of 3
oh ok didnt know that just thought I would need activation code before installing it or during process of installing thanks
2 REPLIES 2
