WIN10 - How do I turn off capslock and numlock popups?
3 ANTWORTEN 3
InteractiveCD
Nachricht 1 von 4
5.509 Aufrufe
Nachricht 1 von 4
5.509 Aufrufe
When caps lock or number lock are toggled, a reminder pops up at the top left of the screen. (MEDION ERAZER DEPUTY P25)
How do I disable this? (checked ease of access settings and notification settings, all relevant options are off.)
Johnmo89
Nachricht 3 von 4
5.455 Aufrufe
Nachricht 3 von 4
5.455 Aufrufe
This is not a windows feature. This is the responsibility of a third party program.
In my case it was Hkcmd. Depending on the brand of your hardware it might be something else, but it will be something related to hotkeys or an abbreviation that (HK)
solution:
1. Task Manager ---> startup -->
2. locate Hkcmd
3. disable it from starting when windows starts
4. restart pc
3 ANTWORTEN 3
Mastermind
Nachricht 2 von 4
5.467 Aufrufe
Nachricht 2 von 4
5.467 Aufrufe
Hi @InteractiveCD ,
you can feel free to arrange this via the regedit.
Go to
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
In the keyboard folder, you search for the string value named "InitialKeyboardIndicators" with put the value to 1 which should disable NumLock
Cheers
Johnmo89
Nachricht 3 von 4
5.456 Aufrufe
Nachricht 3 von 4
5.456 Aufrufe
solution:
2. locate Hkcmd
4. restart pc
tjqscott
Nachricht 4 von 4
2.731 Aufrufe
Nachricht 4 von 4
2.731 Aufrufe
I am running the medion erazer deputy p60 and finally discoverd an option to disable On Screen Display (OSD) by right clicking the control center.
3 ANTWORTEN 3
