WIN10 - How do I turn off capslock and numlock popups?
3 RÉPONSES 3
InteractiveCD
Message 1 sur 4
4 790 Visites
Message 1 sur 4
4 790 Visites
When caps lock or number lock are toggled, a reminder pops up at the top left of the screen. (MEDION ERAZER DEPUTY P25)
How do I disable this? (checked ease of access settings and notification settings, all relevant options are off.)
1 SOLUTION APPROUVÉE
Solutions acceptées
Johnmo89
Message 3 sur 4
4 736 Visites
Message 3 sur 4
4 736 Visites
This is not a windows feature. This is the responsibility of a third party program.
In my case it was Hkcmd. Depending on the brand of your hardware it might be something else, but it will be something related to hotkeys or an abbreviation that (HK)
solution:
1. Task Manager ---> startup -->
2. locate Hkcmd
3. disable it from starting when windows starts
4. restart pc
3 RÉPONSES 3
Mastermind
Message 2 sur 4
4 748 Visites
Message 2 sur 4
4 748 Visites
Hi @InteractiveCD ,
you can feel free to arrange this via the regedit.
Go to
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
In the keyboard folder, you search for the string value named "InitialKeyboardIndicators" with put the value to 1 which should disable NumLock
Cheers
Johnmo89
Message 3 sur 4
4 737 Visites
Message 3 sur 4
4 737 Visites
solution:
2. locate Hkcmd
4. restart pc
tjqscott
Message 4 sur 4
2 012 Visites
Message 4 sur 4
2 012 Visites
I am running the medion erazer deputy p60 and finally discoverd an option to disable On Screen Display (OSD) by right clicking the control center.
3 RÉPONSES 3
