MSN: 10024693 b660m ds3h ax ddr4 motherboard bios update
5 REPLIES 5
krispy
Message 1 of 6
Message 1 of 6
(Edit the MSN number on the motherboard is 20070400 which isnt even on the msn website but the closest I could find is 20070466 which still has nothing under downloads)
Hello, I can not find for the life of me where I can download a bios that I can actually flash, I tried updating to the newest f30 bios version for the motherboard posted on gigabytes website at which point I was met with a Oemid missmatch error. The bios version I am currently on says 100 and its from 2022 which leads me to think its a medion custom bios file and it wont let me update to the official gigabyte bios and instead wants me to update to a medion one but I dont even know if one exists since I couldnt find one on the service website so I need help figuring out where I can find a bios update if there is one or how I could get rid of the custom bios and install the official one. Thanks
5 REPLIES 5
Message 2 of 6
Message 2 of 6
@krispy
You should use punctuation marks, commas and periods, then your text would be better and understandable. So I refuse to  read it at all; 😉
Cheers, daddle
krispy
Message 3 of 6
Message 3 of 6
The **beep** is your problem, i have clearly used punctuation. Anyway here is a dumbed down version for you: I am looking for a bios update for the B660M DS3H ax DDr4 motherboard(MSN: 20070466). Could you please assist me with finding it?
Message 4 of 6
Message 4 of 6
hello @krispy and welcome
your board GIGABYTE B660M DS3H AX DDR4 has the MSN: 20069821
The MSN 20070400 you first specified is the I/O shield on the rear connection cover.
bye Fishtown
Message 5 of 6
Message 5 of 6
@krispy
This part  is completely without punktuation marks. It's  just a mega sentence without  structure.
It's your beep. But under this circumstances  I can't help. Wait for another user who is in a better mood to deal with it. I am sorry.
But I can change your text  into an understandable and readable english, if you want:
 Quote with correction:
"The bios version I am currently on says 100 and its from 2022.  Which makes me think it's a medion custom (OEM) bios.  But it won't let me update with the official Gigabyte bios. I cannot update his OEM Bios with an official Gigabyte bios because of the wrong Bios ID. This was said whilest I was trying to update with the Gigabyte Bios.
But I dont  even know if a new one Medion bios  exists.  I couldn't find one on the Medion service website. That's why i do need help. And  that is why I am figuring out where I can find a Medion bios update, if there is one at all
Or is there a possibility to get rid of te custom (OEM) Bios? How I could get rid of the custom bios and install the official one."
End
So this text sounds for me better.
Valser
Message 6 of 6
Message 6 of 6
Інформація DMI BIOS вашої материнської плати (для довідки)  https://linux-hardware.org/?probe=1dbbeda8cd&log=dmidecode
Посібник:  https://drive.google.com/file/d/11FeAnyABpBL9JUed0HFDsLiwVzEE8V8_/view?usp=drivesdk
Остання версія BIOS 107 (4.02.2025) Gigabyte B660M DS3H AX DDR4 => GAB660MW0X.107 => https://cdn.medion.com/downloads/software/00_bios_ga_b660m_ds3h_ax.zip
5 REPLIES 5
