I cant find the correct driver for medion e7416t sound card
4 ANTWORTEN 4
echida
Nachricht 1 von 5
2.562 Aufrufe
Nachricht 1 von 5
2.562 Aufrufe
The laptop does not have sound I cant find the right drivers for the sound I connected the laptop with hdmi to the tv and jt had sound and right when i took out the hdmi it didnt had sound What are the correct drivers i have to install?
4 ANTWORTEN 4
Nachricht 2 von 5
2.555 Aufrufe
Nachricht 2 von 5
2.555 Aufrufe
Hello @echida  and welcome
Drivers can be found on drive D:drivers
or here: https://www.medion.com/de/service/product-detail/30018189
are the speakers turned off? Fn+F10
do headphones work?
bye Fishtown
M25Jeter
Sleeper
Nachricht 3 von 5
2.312 Aufrufe
Nachricht 3 von 5
2.312 Aufrufe
@echida wrote:
The laptop does not have sound I cant find the right drivers for the sound I connected the laptop with hdmi to the tv and jt had sound and right when i took out the hdmi it didnt had sound What are the correct drivers i have to install? PeopleNet Fleet Manager Login
Download drivers for sound card for Medion Akoya E7416 laptop (Windows 10 x64), or download DriverPack Solution software for driver update.
Thanks,
M25Jeter
EastClintwood
Nachricht 4 von 5
2.308 Aufrufe
Nachricht 4 von 5
2.308 Aufrufe
Hello @M25Jeter, and welcome to the community.
If you have the same problem as the thread creator then I would recommend you to install the sound card driver first.
Greetings,
EastClintwood
M25Jeter
Sleeper
Nachricht 5 von 5
2.298 Aufrufe
Nachricht 5 von 5
2.298 Aufrufe
Greetings,
EastClintwood
Hello, @EastClintwood
Thanks for sharing my friends have same problem now your provide solution is work for him thank you very much..
Thanks,
M25Jeter
4 ANTWORTEN 4
