I cant find the correct driver for medion e7416t sound card
4 ANTWOORDEN 4
echida
Bericht 1 van 5
2.541 Weergaven
Bericht 1 van 5
2.541 Weergaven
The laptop does not have sound I cant find the right drivers for the sound I connected the laptop with hdmi to the tv and jt had sound and right when i took out the hdmi it didnt had sound What are the correct drivers i have to install?
4 ANTWOORDEN 4
Bericht 2 van 5
2.534 Weergaven
Bericht 2 van 5
2.534 Weergaven
Hello @echida  and welcome
Drivers can be found on drive D:drivers
or here: https://www.medion.com/de/service/product-detail/30018189
are the speakers turned off? Fn+F10
do headphones work?
bye Fishtown
M25Jeter
Sleeper
Bericht 3 van 5
2.291 Weergaven
Bericht 3 van 5
2.291 Weergaven
@echida wrote:
The laptop does not have sound I cant find the right drivers for the sound I connected the laptop with hdmi to the tv and jt had sound and right when i took out the hdmi it didnt had sound What are the correct drivers i have to install? PeopleNet Fleet Manager Login
Download drivers for sound card for Medion Akoya E7416 laptop (Windows 10 x64), or download DriverPack Solution software for driver update.
Thanks,
M25Jeter
EastClintwood
Bericht 4 van 5
2.287 Weergaven
Bericht 4 van 5
2.287 Weergaven
Hello @M25Jeter, and welcome to the community.
If you have the same problem as the thread creator then I would recommend you to install the sound card driver first.
Greetings,
EastClintwood
M25Jeter
Sleeper
Bericht 5 van 5
2.277 Weergaven
Bericht 5 van 5
2.277 Weergaven
Greetings,
EastClintwood
Hello, @EastClintwood
Thanks for sharing my friends have same problem now your provide solution is work for him thank you very much..
Thanks,
M25Jeter
4 ANTWOORDEN 4
