extra RAM for Erazer X7851
2 REPLIES 2
JohnJones
Message 1 of 3
Message 1 of 3
Hi, I have an Erazer x7851 laptop and I want to increase the DDR4 RAM from 16 to 64 GB, as I use it for music.
I need someone to point me to a good dealer who can install it, or failing that a good DIY video (PC world were going to give me DDR3 RAM not DDR3, without telling me).. It seems that I have to take the front as well as the back off to install the extra RAM so it looks a bit difficult.
Also, what particular RAM do you suggest for this model?
2 REPLIES 2
Bodgekin
Message 2 of 3
Message 2 of 3
Hi @JohnJones
Are you sure your system supports up to 64 GB? According to this site the X7851 has 2 memory slots, and for 64 GB you'd need 4. It might be a different version of the X7851 though, what is your MSN number?
I've not been able to find any instructional video's on changing the memory of this model so far :(, but it should be DDR4 - 2400Mhz.
Kind regards,
Bart
JohnJones
Message 3 of 3
Message 3 of 3
Thanks for that.  I thought it was the medion advice telephone number people who told me - two slots in the back and two in the front. Maybe not. I'll ring them again.
The msn number is 30022561 (X7851 MD60538)
There are lots of different RAM out there? Any decent ones recommended here for the Medion?
2 REPLIES 2
