expand memory to medion akoya "E3221"
3 REPLIES 3
jimax
Message 1 of 4
Message 1 of 4
Hi, I need help to expand memory to medion akoya "E3221", as far I know the maximum supported is 256g but I don`t know which memory model or brand to buy in order it fits and works well
Thanks to everybody in advance
3 ACCEPTED SOLUTIONS
Message 2 of 4
Message 2 of 4
Hello @jimax and welcome
found that in the shop:
https://www.medion.com/de/shop/p/convertible-notebooks-medion-akoya-e3221-33-8-cm-13-3--fhd-touch-di...
from the description:
SSD Speichererweiterung
Zusätzlich Platz für eine SSD
Darf es ein bisschen mehr sein? Gehe keine Kompromisse mehr ein und erweitere Dein Notebook mit einer zusätzlichen SSD von bis zu 512 GB.
*Zulässiger Formfaktor: m.2. 2280 und SATA Standard. Eine zusätzliche SSD ist nicht im Lieferumfang enthalten.
SSD storage expansion
Additional space for an SSD Would you like a little more? Don't make any more compromises and expand your notebook with an additional SSD of up to 512 GB.
* Valid form factor: m.2. 2280 and SATA standard. An additional SSD is not included in the scope of delivery.
Bye Fishtown
jimax
Message 3 of 4
Message 3 of 4
Then I just buy an ssd of this format (m.2. 2280) and it will work fine?
thanks for your quickly answer @Fishtown
Message 4 of 4
Message 4 of 4
Hi @jimax ,
in deed this will work fine for your MEDION AKOYA E3221 up to a module size of 512 GB.
Cheers
Major Tom
3 REPLIES 3
Message 2 of 4
Message 2 of 4
Bye Fishtown
jimax
Message 3 of 4
Message 3 of 4
Message 4 of 4
Message 4 of 4
Hi @jimax ,
Cheers
Major Tom
3 REPLIES 3
