le 25.06.2021 12:45
le 25.06.2021 12:45
Erazer Gaming notebook P15805.
Almost always after startup from power off state, the WLAN does not work.
Windows Event logs:
1. A corrected hardware error has occurred.
Component: PCI Express Root Port
Error Source: Advanced Error Reporting (PCI Express)
Primary Bus:Device:Function: 0x0:0x1D:0x0
Secondary Bus:Device:Function: 0x0:0x0:0x0
Primary Device Name:PCI\VEN_8086&DEV_A336&SUBSYS_85501558&REV_F0
Secondary Device Name:
2. Intel(R) Wireless-AC 9560 160MHz : Has determined that the network adapter is not functioning properly.
3. Intel(R) Wireless-AC 9560 160MHz : Has encountered an internal error and has failed.
Windows 10 Home, up to date.
Driver provider: Intel
Version: 22.40.0.7
From 3/3/2021
le 25.06.2021 13:28
le 25.06.2021 15:42
le 25.06.2021 15:42
Unfortunately, the same behavior with all intel drivers from the past 18 months.
Latest driver updated today.
25.06.2021 19:38 - modifié 25.06.2021 20:34
I would first of all reinstall the chipset drivers. They are in a map called Driver(s), on your D- or E Drive, and came with the PC.
If you cannnot start the single installation of one driver catagory, just reinstall all.
About the Intel Wlan driver problem there is known, that they are in some way Windows Version dependent. So sometimes a driver works for a while, and suddenly stops getting a connection to the Internet. If then the Win Verson is updated, e.g. from Win 20H2 to Win 21H1, it suddenly works again. So please check this also.
Cheers, daddle
le 27.06.2021 22:36
le 27.06.2021 22:36
Hi @daddle , thanks for your good intention.
All dirvers are up to date from https://www.intel.com/content/www/us/en/support/detect.html
The recovery drivers are in D:\Drivers\07.WIFI .
Is the root cause known?
27.06.2021 22:49 - modifié 27.06.2021 23:00
@someMedUser schrieb:Hi @daddle , thanks for your good intention.
Thats why I say install the Chipsetdriver from origin, the error points to the chipset drivers.
And sometimes newer driver can produce hassle. Especially some Intel Driver in the past caused a lot of trouble.
Edit: For the root cause ask Medion, Microsoft or Intel. 😉
