Medium akoya E3221 storage increment
7 ANTWOORDEN 7
Elsita
Bericht 1 van 8
5.658 Weergaven
Bericht 1 van 8
5.658 Weergaven
Hi all, as said in subject, I would like to increment the storage of my akoya. I know it supports an extra ssd m.2 sata, what I don't know is the maximum capacity that can be connected.
Anyone can clear up this for me?
Thanks.
1 GEACCEPTEERDE OPLOSSING
Geaccepteerd Solutions
Bericht 2 van 8
5.654 Weergaven
Bericht 2 van 8
5.654 Weergaven
Hi @Elsita and welcome
max. 512 Gigabyte
bye Fishtown
7 ANTWOORDEN 7
Bericht 2 van 8
5.655 Weergaven
Bericht 2 van 8
5.655 Weergaven
max. 512 Gigabyte
bye Fishtown
Bericht 3 van 8
5.649 Weergaven
Bericht 3 van 8
5.649 Weergaven
@Elsita
Hi Elsita, first you should give the MSN number of your E3221, because some models come  equipped with eMMC storage, plus an additional free slot for a flash memory expansion module SATA  M.2. Others have no eMMC, but come with an M.2 SSD equipped in the expansion slot already.
Though the manual for both models speaks of:   " Your notebook is equipped with a slot for a flash memory expansion module"
Cheers, daddle
Elsita
Bericht 4 van 8
5.641 Weergaven
Bericht 4 van 8
5.641 Weergaven
Hi all, thanks for your attention.
Allready ordered a 512Gb extra storage from Amazon, it's on the way....hope ir works fine. I'll post results.
By the way, is the RAM also upgreadable, ir is it soldered and no extra slot??
Cheers.
Bericht 5 van 8
5.635 Weergaven
Bericht 5 van 8
5.635 Weergaven
@Elsita
If you do not give us your MD- and MSN Number from the sticker underneath, we can not  help any further. I have a good reason why I ask for it. Didn't you read the manual on page 37
This entry in the manual all models have, although with some of them the expansion slot is occupied already with the boot disk
So what is the disk capacity of your model, and  post the MSN please?
Cheers, daddle
Elsita
Bericht 6 van 8
5.633 Weergaven
Bericht 6 van 8
5.633 Weergaven
Hi @daddle , here is the MSN: 30030700.
Capacity is 64gb emmc.
Thanks.
Bericht 7 van 8
5.628 Weergaven
Bericht 7 van 8
5.628 Weergaven
@Elsita
Ok, then your 500 GB M.2 SSD will fit.
And no, RAM is soldered to the board. It can not be upgraded.
What will help is, to move your OS to the new SSD; reformatting eMMC afterwards and to use it as normal storage.
This will speed your boottime up for about 30%; and also all Windows operations are similar faster; especially if bigger programs are loaded.
Cheers, daddle
Elsita
Bericht 8 van 8
5.618 Weergaven
Bericht 8 van 8
5.618 Weergaven
Thank you @daddle , it's a very good info.
But I don't know how to move the OS from one drive to another.
The storage upgrade is installed and working ..
7 ANTWOORDEN 7
