Medion e3222t only green led ?.
4 REPLIES 4
alexsunny123
Message 1 of 5
Message 1 of 5
Hello,
I bought this laptop, and it worked fine, however when I tried using it today, I only get a black screen, with only the green LED on. It doesn't respond to any keys, and even the Medion logo doesn't show. Tried turning it off and on again, but nothing else happens. Any ideas?
thanks
alexsunny
4 REPLIES 4
Gehringer
Retired
Message 2 of 5
Message 2 of 5
Hi @alexsunny123 and welcome to the FORUM!
Please try connecting your device to an external screen to see if it is an issue with your LCD.
If it does not work, please check if the LED charging light switches on when you connect it to the charger.
If these troubleshooting fails, please contact your local Medion technical support team because it is probably a hardware fault
Regards,
Gehringer
alexsunny123
Message 3 of 5
Message 3 of 5
@alexsunny123 wrote:
Hello,
(3 additional spam-links removed)
thanks
alexsunny
thanks my issue has been fixed.
 @alexsunny123 :
Admin Edit:
Three links to dating websites removed.
Nice try, don`t do it again or you`ll be banned permanently.
Jyselain
Retired
Message 4 of 5
Message 4 of 5
Hi @alexsunny123 , thank you for your feedback.
Would you mind to share what you have done to actually overcome the issue you faced?
Thanks in advance,
Kind regards,
Jyselain
Message 5 of 5
Message 5 of 5
@Thomas151
Something with your answer is very strange. This thread talks about a Laptop model E3222, and some LED charging and a booting problem.
It has nothing to do with a sort of  psychedelic LED Lightshow on a TV.  😉
Got the wrong thread?
cheers, daddle
4 REPLIES 4
