Medion e14409- printer?
2 ANTWOORDEN 2
Anders781
Bericht 1 van 3
2.833 Weergaven
Bericht 1 van 3
2.833 Weergaven
I am trying to connect and use a printer (Canon Pixma MG2550S) to my Medion e14409. The printer works with other laptops but I cannot get it to work with the Medion. I think a part of the issue may be that I do not find a USB port to connect it too, all I can find are LPT1-3: (printer port), COM1-4: (serial port), File: (print to file), nul (local port), and PORTPROMPT: (local port).
I have tried both to download and manually install the printer drivers, and to do it automatically through the canon site without success.
Does anyone know which port I should connect to the printer or do I have to create a new port (and if so, how should I do that)?
1 GEACCEPTEERDE OPLOSSING
Geaccepteerd Solutions
Bericht 2 van 3
2.829 Weergaven
Bericht 2 van 3
2.829 Weergaven
Hello @Anders781 and welcome
I don't quite understand the translation?
Is the printer connected to the E14409 with a MediaRange printer cable / USB(M) - USB Type B(M)
https://asset.conrad.com/media10/add/160267/c1/-/de/849553816DS00/datenblatt-800611510-mediarange-pr...
and is the Canon software and driver installed?
https://www.canon.de/support/consumer_products/products/fax__multifunctionals/inkjet/pixma_mg_series...
You can also connect the printer to the network, for example to the router, but the software should also be installed on the laptop there.
bye Fishtown
2 ANTWOORDEN 2
Bericht 2 van 3
2.830 Weergaven
Bericht 2 van 3
2.830 Weergaven
bye Fishtown
Anders781
Bericht 3 van 3
2.824 Weergaven
Bericht 3 van 3
2.824 Weergaven
Yes, to both questions.
Ohh, I just discovered that windows ran in s mode. This makes it so that only Microsoft store apps can be used. I have disabled it and now the printer works with Medion e14409.
Thank you for your help.
2 ANTWOORDEN 2
