Medion P7618 BIOS big problem
60 ANTWORTEN 60
busa
Nachricht 1 von 61
158.482 Aufrufe
Nachricht 1 von 61
158.482 Aufrufe
hi, I have a problem with my Medion Akoya P7618 (MD98580), I downloaded and flashed the last bios from medion website (http://www.medion.com/de/service/_lightbox/treiber_details.php?did=10611), and now the wifi and external graphics card (GT540M) don't work anymore, how I can fix the problem or where I can download the orginal BIOS for the laptop?
Thanks.
Tags (3)
60 ANTWORTEN 60
busa
Nachricht 31 von 61
95.140 Aufrufe
Nachricht 31 von 61
95.140 Aufrufe
@McB, you're right 🙂
McB
Nachricht 32 von 61
95.136 Aufrufe
Nachricht 32 von 61
95.136 Aufrufe
@busa ...
mostly 😉
unless @daddle extends my answers (within other threads)... a little 'bit' more - but anyway at best!
as i am quite lazy in writting/typing (programmers are lazy) 😉
don't forget to light the 4th candle tomtom & greetinx
Nachricht 33 von 61
95.044 Aufrufe
Nachricht 33 von 61
95.044 Aufrufe
@busa
Hi busa, it is great that it worked. I sent you a PN, please answer it asap.
Thanks, daddle
nnouk
Nachricht 34 von 61
94.683 Aufrufe
Nachricht 34 von 61
94.683 Aufrufe
I have the same problem. What the hell is MEDION doing placing such a wrong doing BIOS update on its website??
Could you please help me and send me the dumped previous BIOS version?
Nachricht 35 von 61
94.624 Aufrufe
Nachricht 35 von 61
94.624 Aufrufe
@nnouk Hallo und willkommen im Forum.
Saying Hello and Bye as well as addressing someone would be a nice gesture!
Aber egal, du hast eine PN.
McB
Nachricht 36 von 61
94.616 Aufrufe
Nachricht 36 von 61
94.616 Aufrufe
@nnouk
and please... 😉
greetinx
nnouk
Nachricht 37 von 61
94.591 Aufrufe
Nachricht 37 von 61
94.591 Aufrufe
only like 3 posts out of 36 include some Hallo so ask them first before teaching new ones please...
anyway the link helped so thx very much
Nachricht 38 von 61
94.571 Aufrufe
Nachricht 38 von 61
94.571 Aufrufe
@nnouk
Well I guess coming new into a forum or thread it is a good habit to say hello. Once you are in a dialog of course you
don't have to say greetings in every answering post again. That's the difference!
Nachricht 39 von 61
93.029 Aufrufe
Nachricht 39 von 61
93.029 Aufrufe
Hallo @daddle.
Wir haben das BIOS Update erstmal entfernt um nicht noch mehr Fälle zu produzieren, in denen sich die Grafikkarte und das WLAN nicht mehr installieren lassen.
Das Gerät ist von 2011 und weder das ursprüngliche BIOS noch das jetzt entfernte wurde im Hinblick auf Windows 10 programmiert. Aufgrund des Alters wird es für dieses Gerät kein aktuelleres BIOS mehr geben. Daher wird das Rückspielen der alten BIOS Version (für die Leute, die schon geflasht haben) der einzige Workaround bleiben.
busa
Nachricht 40 von 61
93.018 Aufrufe
Nachricht 40 von 61
93.018 Aufrufe
@Andi
I installed windows 10 after flash back to 009, and it work without any problem, windows install all required drivers via win update.
60 ANTWORTEN 60
