Medion P7618 BIOS big problem
60 ANTWORTEN 60
busa
Nachricht 1 von 61
157.823 Aufrufe
Nachricht 1 von 61
157.823 Aufrufe
hi, I have a problem with my Medion Akoya P7618 (MD98580), I downloaded and flashed the last bios from medion website (http://www.medion.com/de/service/_lightbox/treiber_details.php?did=10611), and now the wifi and external graphics card (GT540M) don't work anymore, how I can fix the problem or where I can download the orginal BIOS for the laptop?
Thanks.
Tags (3)
60 ANTWORTEN 60
aBash
Nachricht 51 von 61
8.846 Aufrufe
Nachricht 51 von 61
8.846 Aufrufe
Hello, i have the same problem. Need the BIOS 009 File too. Can anyone send me this File?
Nachricht 52 von 61
8.829 Aufrufe
Nachricht 52 von 61
8.829 Aufrufe
@aBash
Read on Page 5 Busas post from 25.12.15, 12:37.
There ia a functioning link for a functioning Bios V 009.
Regards, daddle
Nachricht 53 von 61
8.809 Aufrufe
Nachricht 53 von 61
8.809 Aufrufe
@aBash Did you get the bios-file?
An answer or remark would be fine!
pervoisto4nik
Nachricht 54 von 61
8.204 Aufrufe
Nachricht 54 von 61
8.204 Aufrufe
Hello i need old BIOS version was like 009 Medion P7618 BIOS. can help
Nachricht 55 von 61
8.190 Aufrufe
Nachricht 55 von 61
8.190 Aufrufe
Moin @pervoisto4nik and welcome
have you see the Post 52 from @daddle  ?
https://drive.google.com/open?id=0B70osO6OK2ueZndaWUJQT1FUTDA
Please also read the entire article
pervoisto4nik
Nachricht 56 von 61
8.172 Aufrufe
Nachricht 56 von 61
8.172 Aufrufe
writes =(
ROM file ROMID is not compatible with existing BIOS ROMID.
pervoisto4nik
Nachricht 57 von 61
8.160 Aufrufe
Nachricht 57 von 61
8.160 Aufrufe
I changed the firmware to 009 BIOS
the graphics started to work! wifi does not work =(
Nachricht 58 von 61
8.115 Aufrufe
Nachricht 58 von 61
8.115 Aufrufe
Moin @pervoisto4nik
sorry, you wanted 009, you get 009.
There is no prehistory of you and now wifi does not work.
what should we recommend to you now?
Check network adapter drivers in device manager
Nachricht 59 von 61
8.089 Aufrufe
Nachricht 59 von 61
8.089 Aufrufe
@pervoisto4nik  schrieb:
writes =(
@pervoisto4nik
You have to flash in Admin mode.
Check the drivers in device manager; and check if you switched the wifi accidentally off by FN 7?
regards, daddle
Nachricht 60 von 61
7.096 Aufrufe
Nachricht 60 von 61
7.096 Aufrufe
@Frog
@Frog  schrieb:
Even if I could manage to get the old BIOS version, you would not be able to install it. The flash procedure will find a newer version installed and cancel the process.
To be honest, I really don't think that any of your notebooks issues are caused by the newer (and optimized) BIOS.
Um mal mit diesem alten Mythos aufzuräumen, in diesem Fall (Und in vielen anderen auch ) funktioniert das sehr wohl, und hat es ja nachweislich auch.
Es hängt sicher davon ab, ob das Bios-Update komplett ist.
Und es war in diesem Fall  das Bios V.100B dass die Fehler in Win 10 produzierte, die mit der V 009 nicht auftreten.
60 ANTWORTEN 60
