Medion P7618 BIOS big problem
60 ANTWOORDEN 60
busa
Bericht 1 van 61
158.076 Weergaven
Bericht 1 van 61
158.076 Weergaven
hi, I have a problem with my Medion Akoya P7618 (MD98580), I downloaded and flashed the last bios from medion website (http://www.medion.com/de/service/_lightbox/treiber_details.php?did=10611), and now the wifi and external graphics card (GT540M) don't work anymore, how I can fix the problem or where I can download the orginal BIOS for the laptop?
Thanks.
Tags (3)
60 ANTWOORDEN 60
aBash
Bericht 51 van 61
8.920 Weergaven
Bericht 51 van 61
8.920 Weergaven
Hello, i have the same problem. Need the BIOS 009 File too. Can anyone send me this File?
Bericht 52 van 61
8.903 Weergaven
Bericht 52 van 61
8.903 Weergaven
@aBash
Read on Page 5 Busas post from 25.12.15, 12:37.
There ia a functioning link for a functioning Bios V 009.
Regards, daddle
Bericht 53 van 61
8.883 Weergaven
Bericht 53 van 61
8.883 Weergaven
@aBash Did you get the bios-file?
An answer or remark would be fine!
pervoisto4nik
Bericht 54 van 61
8.278 Weergaven
Bericht 54 van 61
8.278 Weergaven
Hello i need old BIOS version was like 009 Medion P7618 BIOS. can help
Bericht 55 van 61
8.264 Weergaven
Bericht 55 van 61
8.264 Weergaven
Moin @pervoisto4nik and welcome
have you see the Post 52 from @daddle  ?
https://drive.google.com/open?id=0B70osO6OK2ueZndaWUJQT1FUTDA
Please also read the entire article
pervoisto4nik
Bericht 56 van 61
8.246 Weergaven
Bericht 56 van 61
8.246 Weergaven
writes =(
ROM file ROMID is not compatible with existing BIOS ROMID.
pervoisto4nik
Bericht 57 van 61
8.234 Weergaven
Bericht 57 van 61
8.234 Weergaven
I changed the firmware to 009 BIOS
the graphics started to work! wifi does not work =(
Bericht 58 van 61
8.189 Weergaven
Bericht 58 van 61
8.189 Weergaven
Moin @pervoisto4nik
sorry, you wanted 009, you get 009.
There is no prehistory of you and now wifi does not work.
what should we recommend to you now?
Check network adapter drivers in device manager
Bericht 59 van 61
8.163 Weergaven
Bericht 59 van 61
8.163 Weergaven
@pervoisto4nik  schrieb:
writes =(
@pervoisto4nik
You have to flash in Admin mode.
Check the drivers in device manager; and check if you switched the wifi accidentally off by FN 7?
regards, daddle
Bericht 60 van 61
7.170 Weergaven
Bericht 60 van 61
7.170 Weergaven
@Frog
@Frog  schrieb:
Even if I could manage to get the old BIOS version, you would not be able to install it. The flash procedure will find a newer version installed and cancel the process.
To be honest, I really don't think that any of your notebooks issues are caused by the newer (and optimized) BIOS.
Um mal mit diesem alten Mythos aufzuräumen, in diesem Fall (Und in vielen anderen auch ) funktioniert das sehr wohl, und hat es ja nachweislich auch.
Es hängt sicher davon ab, ob das Bios-Update komplett ist.
Und es war in diesem Fall  das Bios V.100B dass die Fehler in Win 10 produzierte, die mit der V 009 nicht auftreten.
60 ANTWOORDEN 60
