Medion Erazer not tun on
3 REPLIES 3
Dachko_666
Message 1 of 4
Message 1 of 4
Hello i have Medion erazer that was working perfect in one moment and in another just turned of and for some reason the laptop was really hot  . Now the laptop doesn’t want to turn on again when I try the touchpad it’s flashing but the laptop is not turning on. The battery is integrated so I can’t take it out  the msn is - 30022237
3 REPLIES 3
Gehringer
Retired
Message 2 of 4
Message 2 of 4
Hi @Dachko_666 ,
I believe your unit will need to be assessed by a technician.
I would advise you to get in touch with your local Medion technical support team.
Is your unit still in warranty?
If so, then the repair is likely to be performed free of charges.
Regards,
Gehringer
Dachko_666
Message 3 of 4
Message 3 of 4
Unfortunately the warranty ends on 01-01-2021 so I will need to pay the repair ... I hope that is not the motherboard
Message 4 of 4
Message 4 of 4
Hi @Dachko_666
report the damage now 31.12.2020 you still have a guarantee.
bye Fishtown
3 REPLIES 3
