Medion Akoya p6685 md 61138
6 REPLIES 6
momo10
Message 1 of 7
Message 1 of 7
Hi,
My charger is not working anymore, I tried to get one with Medion Uk serviceshop, but they don't have it in stock. I contacted them twice, and confirmed that they don't have msn40063264 in stock, and advised me to go on ebay or amazon. there is no charger available on tboth websites. I tried IPC who seems to have it, but they replied that they don't post to the UK. Any idea guys on how to sort this out?
Thank youi
1 ACCEPTED SOLUTION
Message 6 of 7
Message 6 of 7
Hi @momo10
example
bye Fishtown
6 REPLIES 6
Message 2 of 7
Message 2 of 7
Hi @momo10
MSN40063264= FSP090-ABCN2 C8 ErP16 2-Pin 90W
delivery worldwide:
https://www.pcakkusdirekt.de/medion-notebook-netzteile-c-52_22/original-90w-fsp-fsp090abcn2-fsp090dv...
compare the connector: 5.5mm * 2.5mm
Bye Fishtown
momo10
Message 3 of 7
Message 3 of 7
Thank you Fishtown for your replyI really appreciate. When you say compare the connector, do you mean check if the connector is the same as the original that I have?
Message 4 of 7
Message 4 of 7
Hi @momo10
Exactly, unfortunately, the size of the original plug is not stored in the database.
bye Fishtown
momo10
Message 5 of 7
Message 5 of 7
Last question, it says : Plug Size: 5.5mm*2.5mm. Does it mean that the plug size is 2.5mm diameter?
Message 6 of 7
Message 6 of 7
Hi @momo10
example
bye Fishtown
momo10
Message 7 of 7
Message 7 of 7
Thank you so much for your help Fishtown you are a star!
6 REPLIES 6
