Medion Akoya e4410 ram issue
7 ANTWOORDEN 7
zaraf
Bericht 1 van 8
5.053 Weergaven
Bericht 1 van 8
5.053 Weergaven
Hello I tried to upgrade ram using Crucial 16 gb dd4 SODIMM 2666MHZ but the computer doesn't post. The ram was after checked in another computer and it works fine. When I put back in the original 4 GB it works fine.
What is the problem? Compatibiliy issue? What RAM should I use?
7 ANTWOORDEN 7
Bericht 2 van 8
5.048 Weergaven
Bericht 2 van 8
5.048 Weergaven
Hello @zaraf  and welcome
please state your msn number
I can't find an e4410
bye Fishtown
zaraf
Bericht 3 van 8
5.045 Weergaven
Bericht 3 van 8
5.045 Weergaven
Hello its a typo sorry. The model number is e14410
zaraf
Bericht 4 van 8
5.028 Weergaven
Bericht 4 van 8
5.028 Weergaven
Oh and my number is 30031494
Bericht 5 van 8
5.020 Weergaven
Bericht 5 van 8
5.020 Weergaven
@zaraf
Basically the specs of the RAM you bought are correct.
 They orig. are:
1x 4096 MB DDR4 SO-DIMM (PC4-21300 / 2666 MHz) (1/1 covered; 32 GB max.)
So you bought a 16 GB module of same specs
But it could be that the organization of the RAM chips is a bit different.
You are sure the RAM module was seated correctly?
So please post a link from your supplier, to check the specs of the new RAM.
Cheers, daddle
xx
zaraf
Bericht 6 van 8
5.012 Weergaven
Bericht 6 van 8
5.012 Weergaven
@daddle
Hey, so the thing is I got the ram used. It came with the packaging though and on the packing it says CT16G4SFRA266
I am sure it seated correctly and it is not damaged because it works on my other laptop (zenbook ux410).
Bericht 7 van 8
5.004 Weergaven
Bericht 7 van 8
5.004 Weergaven
@zaraf
As I said, may be a different organization structure.
Bericht 8 van 8
5.002 Weergaven
Bericht 8 van 8
5.002 Weergaven
Hi @zaraf
One could ask deyu23. he also wanted to increase the RAM on his e14410.
https://community.medion.com/t5/Notebook-Netbook/Medion-Akoya-E14410/m-p/128166#M1042
hello @deyu23  did you increase your memory and were there any difficulties?
bye Fishtown
7 ANTWOORDEN 7
