Medion Akoya e4410 ram issue
7 RÉPONSES 7
zaraf
Message 1 sur 8
5 126 Visites
Message 1 sur 8
5 126 Visites
Hello I tried to upgrade ram using Crucial 16 gb dd4 SODIMM 2666MHZ but the computer doesn't post. The ram was after checked in another computer and it works fine. When I put back in the original 4 GB it works fine.
What is the problem? Compatibiliy issue? What RAM should I use?
7 RÉPONSES 7
Message 2 sur 8
5 121 Visites
Message 2 sur 8
5 121 Visites
Hello @zaraf  and welcome
please state your msn number
I can't find an e4410
bye Fishtown
zaraf
Message 3 sur 8
5 118 Visites
Message 3 sur 8
5 118 Visites
Hello its a typo sorry. The model number is e14410
zaraf
Message 4 sur 8
5 101 Visites
Message 4 sur 8
5 101 Visites
Oh and my number is 30031494
Message 5 sur 8
5 093 Visites
Message 5 sur 8
5 093 Visites
@zaraf
Basically the specs of the RAM you bought are correct.
 They orig. are:
1x 4096 MB DDR4 SO-DIMM (PC4-21300 / 2666 MHz) (1/1 covered; 32 GB max.)
So you bought a 16 GB module of same specs
But it could be that the organization of the RAM chips is a bit different.
You are sure the RAM module was seated correctly?
So please post a link from your supplier, to check the specs of the new RAM.
Cheers, daddle
xx
zaraf
Message 6 sur 8
5 085 Visites
Message 6 sur 8
5 085 Visites
@daddle
Hey, so the thing is I got the ram used. It came with the packaging though and on the packing it says CT16G4SFRA266
I am sure it seated correctly and it is not damaged because it works on my other laptop (zenbook ux410).
Message 7 sur 8
5 077 Visites
Message 7 sur 8
5 077 Visites
@zaraf
As I said, may be a different organization structure.
Message 8 sur 8
5 075 Visites
Message 8 sur 8
5 075 Visites
Hi @zaraf
One could ask deyu23. he also wanted to increase the RAM on his e14410.
https://community.medion.com/t5/Notebook-Netbook/Medion-Akoya-E14410/m-p/128166#M1042
hello @deyu23  did you increase your memory and were there any difficulties?
bye Fishtown
7 RÉPONSES 7
