Erazer P6705 keyboard replacement
8 REPLIES 8
Ikarusnc
Message 1 of 9
Message 1 of 9
Hi there, I'm wondering if there is a guide on how to remove the keyboard, backlight is not working and I want to repair it or replace it. Thank you for your help!
8 REPLIES 8
Message 2 of 9
Message 2 of 9
moin @Ikarusnc and welcome
is she just turned off? please refer : S.30 /http://download2.medion.com/downloads/anleitungen/bda_p6705_p6605_en.pdf
Fn + F4 Keyboard lighting on/off // brightness down // brightness up.
or do the quick start buttons not go and thus the lighting can not be switched on?
Maybe only one driver is missing?
bye Fishtown
Ikarusnc
Message 3 of 9
Message 3 of 9
I know about fn+f4 and installed every driver from medion. I unmounted the keyboard successfully and I found that the led power connector is probably faulty, moving it turned on the led but after few minutes it turned off (timer is set to off) and I had to unmount again.
Message 4 of 9
Message 4 of 9
moin @Ikarusnc
some users in other forum wrote that they have the problem after an update. is that the case with you?
bye Fishtown
Ikarusnc
Message 5 of 9
Message 5 of 9
It is possible indeed, I noticed it after an update but the second time moving the connetor was not enough, I had to remove the battery and reset in order to get the led working again. Keyboard backlight has to work on Windows loading also. Do you think can be a Windows update problem? If is software seems more a BIOS problem to me. Thank you for your help
Message 6 of 9
Message 6 of 9
moin @Luke
Question: Are you aware that it is after a Windows or BIOS update a change in the timer setting keyboard lighting was used to save energy?
Moin @Ikarusnc , Luke is medion's communication manager, maybe he has an answer.
bye-Fishtown
Ikarusnc
Message 7 of 9
Message 7 of 9
If you mean the Control Center timer (software installed with hotkeys driver from medion), yes I noticed it and disabled it (no turn off timer)
Message 8 of 9
Message 8 of 9
moin @Ikarusnc
Do you have in the UEFI setting (F2 after the turn on) the possibility to adjust the keyboard lighting?
bye-Fishtown
Ikarusnc
Message 9 of 9
Message 9 of 9
I don't see any keyboard light related option inside BIOS, only option to change fn function.
8 REPLIES 8
