ERAZER CRAWLER E10 USB Specifications and Support? MSN: 30033537
2 ANTWORTEN 2
OrdinaryBiscuit
Nachricht 1 von 3
1.202 Aufrufe
Nachricht 1 von 3
1.202 Aufrufe
Hi,
So after looking online etc. I've been unable to find the exact specification of the USB ports on this laptop, there's a lot of conflicting info.
Are the type A ports USB 3.0 or 3.1 and what's the difference there?
Is the Type C port USB 3.1 or 3.2? And what does it support? (Display Port, Power Delivery, Thunderbolt?) I was considering using a dock with a display out though I wasn't sure if it was supported.
What speeds etc. should I expect from the ports on this device?
Thanks,
- Biscuit
2 ANTWORTEN 2
Nachricht 2 von 3
1.179 Aufrufe
Nachricht 2 von 3
1.179 Aufrufe
@OrdinaryBiscuit
You can find the Manual here
--> https://www.medion.com/de/service/product-detail/30033537
Cheers, daddle
Nachricht 3 von 3
949 Aufrufe
Nachricht 3 von 3
949 Aufrufe
Hi @OrdinaryBiscuit  and sorry for the late reply.
The USB port interface specifications of the Crawler E10 laptop are the following:
1 x USB 2.0 port Type A
2 x USB 3.2 Gen 1 port Type A
1 x USB 3.2 Gen 2 port TypeC
The Type-C port is just for data transport only and does not support DP or PD
Cheers
2 ANTWORTEN 2
