solution to stop ventilation?
1 REPLY 1
Nomi613
Message 1 of 2
Message 1 of 2
Hello everyone, I've just bought a Medion Erazer Deputy P40 which I find extra except for one thing, this ventilation that declenches at 25% above 40 ° C, is it possible to change that?
The computer doesn't heat up at all, it would be great to be able to change this to 15/20% or switch it off after 50°C.
I should point out that I was able to take all the information about the fan speed from the Control Center Package application.
thank you
1 REPLY 1
Mastermind
Message 2 of 2
Message 2 of 2
Hi @Nomi613 ,
could you please give us some information, if this issue still occurs and what´s the Bios version, showing on the startscreen of your bios ?
Bios should be: 1.07.09RME2
Cheers
P.S. Another hint: To mention a community user so that they are notified when you reply, write an @ sign in front of their name (e.g. @Major_Tom)
1 REPLY 1
