E15307 - second SSD Slot?
2 ANTWOORDEN 2
Wip
Bericht 1 van 3
3.016 Weergaven
Bericht 1 van 3
3.016 Weergaven
Hello,
I have been looking everywhere but did not find an answer. Does the E15307 come with a second m.2 slot to expand the storage?
Thanks
1 GEACCEPTEERDE OPLOSSING
Geaccepteerd Solutions
Mastermind
Bericht 3 van 3
2.914 Weergaven
Bericht 3 van 3
2.914 Weergaven
Hi @Wip ,
sorry for the late reply, but the MEDION AKOYA E15307 has the option to take another m.2 SDD with the capacity of 1000 GB max.
Cheers
2 ANTWOORDEN 2
Bericht 2 van 3
3.011 Weergaven
Bericht 2 van 3
3.011 Weergaven
@Wip
Hi, to give you a correct answer you should tell us rhe MSN number of your PC.
Your Notebook has a bottom slot called a slot for flash memory expansion module (M.2 2280 SATA).
But most probably this slot already contains your boot ssd. But I am not completely sure. This usually is regular with the Emdoor barebones.
cheers, dadddle
Mastermind
Bericht 3 van 3
2.915 Weergaven
Bericht 3 van 3
2.915 Weergaven
Hi @Wip ,
Cheers
2 ANTWOORDEN 2
