BIOS Update Medion Akoya S14409
12 REPLIES 12
Orman
Message 1 of 13
Message 1 of 13
Hi,
Is there a BIOS update available for Medion Akoya S14409 MSN: 30033486?
I set keyboard backlight to 30 seconds timer in bios instead of always on as default. But when I start typing, there is delay for several seconds until backlight is activated.. maybe a newer bios update can fix this? I will of course update on my own risk.
12 REPLIES 12
Orman
Message 11 of 13
Message 11 of 13
@Major_ToM
Ok, thank you. Is it correct that BIOS updates are distributed with windows updates for this laptop? Or must be manually flashed?
Message 12 of 13
Message 12 of 13
@Orman
It's a nuisance to ask the same  questions over and  over again.
As I told you in post 2 and post 6 already, Bios Updates will and should be distributed by Windows update for all newer Medion PCs.
The bad thing is, very often those updates come quite late, and with some models not at all.
Forgotten , or Windws update takes too long for distribution.
Mastermind
Message 13 of 13
Message 13 of 13
HI; @Orman ;
a bit time delay is normal but we can surely forward your request to the manufacturer in case they´re planning to provide a further update, somewhen in the near future
It´s always good to check for further Windows online updates, but if we receive somthing similar, we will let you know.
Cheers
12 REPLIES 12
