BIOS Update Medion Akoya S14409
12 RÉPONSES 12
Orman
Message 1 sur 13
9 654 Visites
Message 1 sur 13
9 654 Visites
Hi,
Is there a BIOS update available for Medion Akoya S14409 MSN: 30033486?
I set keyboard backlight to 30 seconds timer in bios instead of always on as default. But when I start typing, there is delay for several seconds until backlight is activated.. maybe a newer bios update can fix this? I will of course update on my own risk.
12 RÉPONSES 12
Orman
Message 11 sur 13
2 229 Visites
Message 11 sur 13
2 229 Visites
@Major_ToM
Ok, thank you. Is it correct that BIOS updates are distributed with windows updates for this laptop? Or must be manually flashed?
Message 12 sur 13
2 220 Visites
Message 12 sur 13
2 220 Visites
@Orman
It's a nuisance to ask the same  questions over and  over again.
As I told you in post 2 and post 6 already, Bios Updates will and should be distributed by Windows update for all newer Medion PCs.
The bad thing is, very often those updates come quite late, and with some models not at all.
Forgotten , or Windws update takes too long for distribution.
Mastermind
Message 13 sur 13
2 182 Visites
Message 13 sur 13
2 182 Visites
HI; @Orman ;
a bit time delay is normal but we can surely forward your request to the manufacturer in case they´re planning to provide a further update, somewhen in the near future
It´s always good to check for further Windows online updates, but if we receive somthing similar, we will let you know.
Cheers
12 RÉPONSES 12
