BIOS Update Medion Akoya S14409
12 ANTWOORDEN 12
Orman
Bericht 1 van 13
9.559 Weergaven
Bericht 1 van 13
9.559 Weergaven
Hi,
Is there a BIOS update available for Medion Akoya S14409 MSN: 30033486?
I set keyboard backlight to 30 seconds timer in bios instead of always on as default. But when I start typing, there is delay for several seconds until backlight is activated.. maybe a newer bios update can fix this? I will of course update on my own risk.
12 ANTWOORDEN 12
Orman
Bericht 11 van 13
2.201 Weergaven
Bericht 11 van 13
2.201 Weergaven
@Major_ToM
Ok, thank you. Is it correct that BIOS updates are distributed with windows updates for this laptop? Or must be manually flashed?
Bericht 12 van 13
2.192 Weergaven
Bericht 12 van 13
2.192 Weergaven
@Orman
It's a nuisance to ask the same  questions over and  over again.
As I told you in post 2 and post 6 already, Bios Updates will and should be distributed by Windows update for all newer Medion PCs.
The bad thing is, very often those updates come quite late, and with some models not at all.
Forgotten , or Windws update takes too long for distribution.
Mastermind
Bericht 13 van 13
2.154 Weergaven
Bericht 13 van 13
2.154 Weergaven
HI; @Orman ;
a bit time delay is normal but we can surely forward your request to the manufacturer in case they´re planning to provide a further update, somewhen in the near future
It´s always good to check for further Windows online updates, but if we receive somthing similar, we will let you know.
Cheers
12 ANTWOORDEN 12
