Audio and Batterie
2 ANTWORTEN 2
Hesham
Nachricht 1 von 3
1.268 Aufrufe
Nachricht 1 von 3
1.268 Aufrufe
Audio and Batterie
 Hello,
i have Notebook AKOYA model E2216T after Windows update ,Ton dosent work i have x over Ton Symbol
 have any one Solutions  for me
Thank you
2 ANTWORTEN 2
Luke
Community Manager
Nachricht 2 von 3
1.192 Aufrufe
Nachricht 2 von 3
1.192 Aufrufe
Hello @Hesham,
If the problem still persists, go to the device manager and check the audio driver. You can remove it if necessary and Windows should then install it automatically after a restart.
Sorry for the late reply,
Luke
Nachricht 3 von 3
1.189 Aufrufe
Nachricht 3 von 3
1.189 Aufrufe
@Hesham
Normally the x  over the Ton(?) loudspeaker symbol says Volume swichted off. Or do you mean the Audio catagory  in Device Manager?
Like you wrote here, and got the answer already?
And why didn't  you answer the  Mods hint, to give us an update, if my answer solved your problem?
2 ANTWORTEN 2
