Additional M.2 drive - what spec please?
2 REPLIES 2
Captainbeaky
Message 1 of 3
Message 1 of 3
Hi, I've got a Medion Akoya 15303. Very happy with it.
I'd like to add an additional M.2 drive to it - there is a spare space for one in the bottom of the case.
The label says M.2 2280 PCIE/SATA
Which is reccomended please (PCiE or SATA?)
I was considering the Crucial P2 1TB PCIe M.2 2280SS SSD
Is this a suitable specification (Will it work with my laptop please?)
Kind regards,
Mike.
1 ACCEPTED SOLUTION
Captainbeaky
Message 3 of 3
Message 3 of 3
Ahh - darn it - I missed that in the manual - thank you very much for noting it - much appreciated.
I thought I had read SATA only, but couldn't find out where, and the PCIe/SATA  label on the inside face of the little cover that you remove to fit the drive, and is what got me wondering.
Thanks for that - SATA it is! Chocks away!
I have a lot of reference material and design data (Parts catalogues, service manuals, CAD files and 3D data) are on my networked drive at home and are mirrored on a plug in hard drive, but if I fit a second SSD to this laptop, it makes things a little more convenient and faster (and I think I can automate it to keep both the shared drive and my internal drive mirrored)
As a side note - I've bought this laptop to change back from Mac to PC - Apple stopped supporting my long loved 27" imac, so Fusion360 no longer runs on it! This was really frustrating, as the hardware spec of the imac is still pretty good. I did try Bootcamp, but I can only get it running Windows 8, and really need 10.....
Apples response is to buy a new computer - so I did - a PC!
2 REPLIES 2
Message 2 of 3
Message 2 of 3
@Captainbeaky
Hi Mike,
The manual for your PC says on page 34 the free empty space  from underneath only can be fitted with a SATA M.2 SSD.
"19. Slot for flash memory expansion module M.2 2280
Your notebook comes with a slot for a flash memory expansion module.
The free slot only supports SATA."
Where do you find the label saying PCIe or SATA?
Please state the MSN number for your notebook.
Captainbeaky
Message 3 of 3
Message 3 of 3
2 REPLIES 2
