URGENT - Need driver Medion akoya e3216
11 ANTWORTEN 11
donky
Nachricht 1 von 12
9.663 Aufrufe
Nachricht 1 von 12
9.663 Aufrufe
Hello
WHere I can find drivers for networking/lan and wifi for medion akoya e3216 which is compatibility with windows 10.
11 ANTWORTEN 11
Gehringer
Retired
Nachricht 2 von 12
7.925 Aufrufe
Nachricht 2 von 12
7.925 Aufrufe
Hi @donky ,
currently Medion does not offer links to drivers and firmwares updates.
It recommends using the update feature on Windows 10 because it makes it easier to find the latest software, firmware updates and new hardware drivers, since It detects most devices automatically and installs the necessary drivers, software and firmware updates when you're connected to the Internet.
Regards,
Gehringer
donky
Nachricht 3 von 12
7.923 Aufrufe
Nachricht 3 von 12
7.923 Aufrufe
Thanks for replay
But I can not install from update, I have formated whole hdd and there is no drivers for wifi or lan connections.
Gehringer
Retired
Nachricht 4 von 12
7.918 Aufrufe
Nachricht 4 von 12
7.918 Aufrufe
Hi @donky ,
how old is your Akoya? Can you please provide me the MSN number of your product, also?
Regards,
Gehringer
donky
Nachricht 5 von 12
7.910 Aufrufe
Nachricht 5 von 12
7.910 Aufrufe
I really can not remember how old it is, think from 2017. But here is msn number: 30023137
Gehringer
Retired
Nachricht 6 von 12
7.774 Aufrufe
Nachricht 6 von 12
7.774 Aufrufe
Hi @donky ,
you should be able to find the drivers listed on your Windows 10.
Go to Device Manager -> Network Adapters and then expand this section
Right click on each driver listed and select the "update driver" option
When asked, select the automatic update option, so W10 will go to manufacturer's website and look for the best driver available
Alternatively, your network adapter is the WLAN Intel AC3165 SP AC+BT D2WG, so you can go to Intel website and find the drivers for it.
The link for the UK driver website is here
Please let me know if it has solved the issue.
Regards,
Gehringer
donky
Nachricht 7 von 12
7.728 Aufrufe
Nachricht 7 von 12
7.728 Aufrufe
No, and I don´t understand why is there any drivers. I have formated my drive and backup is removed so I can not take factory install. This is NOT old machine and I don´t understand, why there is NOT any drivers which can be used for win10.
Gehringer
Retired
Nachricht 8 von 12
7.499 Aufrufe
Nachricht 8 von 12
7.499 Aufrufe
Hi @donky ,
I am sorry but it is not clear to me:
Have you tried updating the drivers from W10 device manager as suggested?
Also, have you visited the manufacturer's website?
Regards,
Gehringer
donky
Nachricht 9 von 12
7.427 Aufrufe
Nachricht 9 von 12
7.427 Aufrufe
I have tried everything, windows update is not giving me any drivers. And I have visited the manufacturer's website here on medion only documents to download, which I can not use! Weird and so uproffesionall to remove drivers from it for this model!
Gehringer
Retired
Nachricht 10 von 12
7.346 Aufrufe
Nachricht 10 von 12
7.346 Aufrufe
Hi @donky ,
have you checked the link to the Intel website that was suggested?
Regards,
Gehringer
11 ANTWORTEN 11
