Medion Erazer P10 Engineer : Network driver missing
7 ANTWORTEN 7
RafDef
Nachricht 1 von 8
7.255 Aufrufe
Nachricht 1 von 8
7.255 Aufrufe
 Hello, i just buy a new pc. During the first windows 11 setup, i was stuck to the screen "Lets connect you to a network" Ethernet not connected and no options for wireless connection. So i got an ethernet cable and it was ok but i still want a wifi adapter driver who is totally missing...Does someone know please where i can download the good wifi adapter for this pc ? Do i need to mention that i have already loose 1 day of my life trying to fix that problem...
7 ANTWORTEN 7
Nachricht 2 von 8
7.249 Aufrufe
Nachricht 2 von 8
7.249 Aufrufe
@RafDef
To be able to help you you first should state which Erazer  P10 Engineer   you have.
You must name the MSN -number ( 8 digits, begins with 100.....), and also the MD-number
The service Page for the Engineer P10 you find here:    >> https://www.medion.com/de/service/topic/medion-products?msnCheck=P10%20Engineer
Drivers are  listed on the D- or E-Partition in the directory "Drivers"
RafDef
Nachricht 3 von 8
7.243 Aufrufe
Nachricht 3 von 8
7.243 Aufrufe
  MSN 10024796     MD 35354
 Surprisingly, i have only 1 drive C   Thx for responding
Nachricht 4 von 8
7.228 Aufrufe
Nachricht 4 von 8
7.228 Aufrufe
@RafDef
Yes  you have a 1 TB M.2 SSD. Isn't there not a  second partition on it?
Where did you buy the PC? A private bargain?
Didn't  you go onto the service page and scrolled down for your model with the MSN you have? And than checked the technical specifications.
Wee, your PC was sold  without a Wifi card.
You do need a card
  • 1 x M.2 (E-Key 2230 for Wifi only, Support CNVI)
But still a driver set should be on your  drive, of in C:\,  or on a D-
or E-Partition
But you will find suitable WiFi driver in Internet, if you e.g. buy a Realtek or an Intel Wifi card .
RafDef
Nachricht 5 von 8
7.227 Aufrufe
Nachricht 5 von 8
7.227 Aufrufe
 I buy it with Coolblue online and reading the specifications, it was not obvious, honestly i didn't know some PC was sold without wireless adapter...But i can assure you i have only 1 partition C 1TB and i just see now i have a WirelessSetup inside... Thx for the help, i guess its maybe more easy in this case to exchange it .
Nachricht 6 von 8
7.225 Aufrufe
Nachricht 6 von 8
7.225 Aufrufe
@RafDef
OK C-Drive only. But the wireless setup drivers are for the modifications of the Engineer P10, it's  one driverset for all models.
Nachricht 7 von 8
7.217 Aufrufe
Nachricht 7 von 8
7.217 Aufrufe
Bonjour @RafDef et bienvenue
pour l'emplacement pour carte wan, voir ici :
https://community.medion.com/t5/Ordinateurs-portables/Wifi/m-p/158246#M601
au revoir Fishtown
Nachricht 8 von 8
6.785 Aufrufe
Nachricht 8 von 8
6.785 Aufrufe
@RafDef
But your PC mainboard is equipped with  LAN, you could connect with the router
Why don't or didn't you make use of this?
cheers, daddle
7 ANTWORTEN 7
