2.0 HDDrive 2 Go 640MB
4 REPLIES 4
rdmd
Message 1 of 5
Message 1 of 5
Some years ago I purchased this hard disk drive from Aldi in UK but have never used it.
I would like to use it now but the product is for Windows XP/Vista and my newer lap top ( Dell Inspiron 15 ) is Windows 10.
Can it therefore be used with a Windows 10 Operating System and if so would it be NTFS, FAT or FAT32. The processor is a 64 bit.
Thanks for any help in anticipation.
4 REPLIES 4
RAZZ
Message 2 of 5
Message 2 of 5
Hi @rdmd
It sounds like the external drive will not be compatible due to the age, if you could reply with the MSN or MD number (should be found on a small sticker on the device) I can verify its compatibility.
thanks
rdmd
Message 3 of 5
Message 3 of 5
Thanks for your help.
The numbers are as follows
MD 90103
MSN 5003 0651
RAZZ
Message 4 of 5
Message 4 of 5
@rdmd
unfortunately your drive is only compatible with devices running the following operating systems-
  • Microsoft Windows XP, Windows Vista, Windows 7
Thanks
Message 5 of 5
Message 5 of 5
@rdmd  @RAZZ
Off course you can use this drive. It was delivered with a plug-in power supply, and it can be connected to an USB A-Port (V2.0) or an eSATA port.
But nowadays no newer laptop are equipped with an eSATA  port anymore; so you have to make of an USB 2 cablíng. Which limits the data transfer to max 480 Mbit/s .
@RAZZ
Why should a external drive not be compatible to Win 10 or 11?  Connected per USB cable.
At the time of launching the HDD Drive 2 Go  Windows 7 was the highest Windows version.
Even internal IDE drives would be handled by Win 10 or 11,  if the PC has an IDE port for connecting..
Cheers, daddle
4 REPLIES 4
