password reset for UEFI Erazer DEPUTY P60i
3 REPLIES 3
Polo111
Message 1 of 4
Message 1 of 4
Hello, i know there is a slim chance for this but still i ask : is there a way to reset the UEFI password for Erazer DEPUTY P60i?
   thanks in advance .
  P.S. - don't try to change the UEFI password after your anniversary - too much wine involved 😑
1 ACCEPTED SOLUTION
RAZZ
Message 3 of 4
Message 3 of 4
hI   @Polo111
You can try the below-
Remove CMOS battery
Open the case and locate the small round CMOS battery on the motherboard.
Carefully remove it for 10–30 minutes then reinsert and boot.
NOTE: on many modern systems this does not clear a supervisor/UEFI password,
Disclaimer :- Upgrades and modifications to your PC/laptop should only be carried out by a qualified specialists. If you do not have the necessary qualifications, have the work
carried out by a qualified service technician.
Thanks
3 REPLIES 3
Message 2 of 4
Message 2 of 4
@Polo111
I am afraid you have  to send your Deputy in to Medion for service.
Good luck
RAZZ
Message 3 of 4
Message 3 of 4
hI   @Polo111
Remove CMOS battery
Thanks
Polo111
Message 4 of 4
Message 4 of 4
"Disclaimer :- Upgrades and modifications to your PC/laptop should only be carried out by a qualified specialists. If you do not have the necessary qualifications, have the work carried out by a qualified service technician."
    i know and i am the qualified specialist. unfortunatelly at the time i was the slightly drunk qualified specialist 😔
removing the cmos battery is not clearing the uefi pass.
thank you for taking your time to respond
  edit : fortunatelly for me, i have the habit to keep a logbook when im working . found the password there and the note  " at least you're not driving :)"
3 REPLIES 3
